shackle flip questions.....I searched!!!
Discussion in 'The Garage' started by bigbadchev84, Sep 5, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok i did a little searching on shackle flips and haad a couple questions that i didnt find the answers to. I am interested in fabbing up something alon the lines of the Echobit flip, will it effect my pinion angle at all? i am looking to ditch my 6inch blocks in favor of smaller ones.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes is will. with a 4" shackle flip it will change the pinion angle about 7-8*. a 6" (im guessing here) will change it 10-12*
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok is that alot? i had an 8 inch lift on my truck before, but now i am running 8 inch springs and a 6 inch block, i had rotated my axle perches before with the 8 inch but i am needeing a little more i am guessing......so it will point it up correct? thanks
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    In my case with Echobit flip , 2wd 12 bolt housing , and stock springs , it pointed the pinion at the transfercase , perhaps a hair down . Allowing me to use a CV with the perches staying put .
  5. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Lose the blocks.......the shackle flip will drop the rear of the spring 8" creating 4" total chassis lift.
    The driveline angle will be perfect for a CV shaft.
  6. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    with my echobit flip and AAL my pinion is stright on with the dline now :D
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    fixed it for you.
