Shackle flip queston
Discussion in 'The Garage' started by tomford, Mar 15, 2007.
  1. tomford
    tomford 1/2 ton status Premium Member
    Jan 19, 2006
    921
    7
    New Hampshire
    hey guys
    I was wondering if i could run a shackle flip and get 6 inches of lift out of it. i have a 4 inch lift, springs in the front and 4 inch lift block in the back. I want to get 6 inch front lift springs and do a shackle flip in the rear using the stock springs, taking out the blocks.
    Tom Ford
  2. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    I don't think you can use stock springs and get 6" w/the shackle, but I could be wrong. I am sure someone else will chime in.
    You could get close with stock springs/ 4"shackle and zero rates=5".
    I think you would have to buy 4" springs and use 2" shackles?
  3. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    the diy4x kits are available with different shackle lengths (not that you couldn't use longer shackles on the other brands) so more height is possible. correct me if i'm wrong, but i believe the lift increase is 1/2 the shackle increase. so if a 4" (which seems to be the standard) shackle gives 4" lift, then a 6" would give 5" lift, etc.
  4. tomford
    Jan 19, 2006
    921
    7
    New Hampshire
    so the 6 inch front springs with the shackle flip with 6inch shackles and a zero rate would be about level?
    Tom Ford
  5. PDXCHVY
    PDXCHVY Registered Member
    May 18, 2005
    11
    PDX
    4" shackle flip plus zero rates would give you 5" lift then you would need 2" longer shackles to get 6 inches of lift. I'm running a blank on how long the stock shackles are. Hope that helps you out.:waytogo:
  6. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I *think* that stock shackles are around 4.5" long.. or right around there.
  7. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    When I go shackle flip, I will use m current 2 inch add a leaves, and a zero rate. That should give me about 7 inches of lift in the rear.
