shackle flip rock...
Discussion in 'OffRoad Design' started by jms, Mar 18, 2003.
  1. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Seven rivets out, five to go, and my ears are ringing from the drill, air chisel, air punch, and compressor - Stephen, can't you invent something that'll make these things want to come off? Beam them out? Then again, I could just wear earplugs.... /forums/images/graemlins/smile.gif
    Changed the post title from blues to a more applicable music term, considering the ruckus /forums/images/graemlins/laugh.gif
  2. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Re: shackle flip blues...
    Torch and air hammer. It took me maby 5 minutes to get them all out. Drill? man your doing it the slow way. No wonder you got the blues...
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    You got to wear ear plugs or mickey mouse ears when using tools like that. Or you'll be saying what, what, WHAT in a few years. /forums/images/graemlins/thumb.gif
  4. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Don't mean to rub it in, but GM must have run out of rivets the day they put my frame together! Mine came with BOLTS from the factory, made it a cinch! No one can ever believe it, but that's how it was (truck was TOTALLY stock when I bought it, and the bolts were never touched before me)...guess I got real lucky.
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    All I used was the acetalene torch and I had all 12 rivets out in 3 minutes or less /forums/images/graemlins/deal.gif. Just torched them and smacked the hanger with a BFH and in two whacks it fell off /forums/images/graemlins/thumb.gif.
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    It's not a fast process....but since I've now done it TWO times.....I'll share my secret.
    - Use an angle grinder or cutoff wheel to create a flat spot on the rivet.
    - Centerpunch the rivet so a drillbit won't "walk off" it.
    - Use around a 1/4" drill bit to drill almost entirely through the rivet.
    - Using a drift (or a large phillips screwdriver!) hammer out the remains of the rivet.
    Once you remove the majority of the "guts" of the rivet, there's no real strength to hold it there and it sort of collapses away from the hole. I started out grinding EACH rivet all the way flush and still couldn't get them through the frame holes.....that's when I came across this idea.
    Anyway, it's my technique but you want to try it, you may save yourself some time! /forums/images/graemlins/thumb.gif
  7. jms
    Jan 24, 2001
    1,683
    Thanks everyone for their suggestions; got them all out now /forums/images/graemlins/thumb.gif Torch won't work for me - no open flame in the garage allowed. Greg, I ended up pretty much with what you suggested: center punch // drill with small bit // drill with 1/2 inch bit almost to frame // air chisel rivet head off // air punch the center thru frame. I gotta get the exhaust out of the way; I think the next fun thing is to get the old bushings out. I'm going to use a drill on the spring bushing, but have a question about the shackle: I wonder if I submerge the shackles in Carb cleaner, shouldn't that pretty much soften up or dissolve the old bushings? Anyone tried that?
  8. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    i toke my shackel's outside and burned the bushing's out /forums/images/graemlins/grin.gif
    dave
  9. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'm kinda in the same boat. I'm moving the gastank up so I've been grinding out the rivits. Dont have a torch but I think I'll just rent one. Should be worth it. /forums/images/graemlins/tongue.gif
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    drilling out rivets sucks... i did it with my shackle flip and it took forever. the best way to do it on the cheap (no torch setups or any of that jazz) is to get a cheap 4.5" angle grinder and just grind the heads completely off. then you use big punch or socket extension or something, put it on the shaft of the rivet and hit it with a BFG. I took some bumpstop brackets off my rig once with the grind method and it was sooooooo much faster and easier than drilling. /forums/images/graemlins/smile.gif that one job paid for the grinder by itself in that I avoided hours of agravation. /forums/images/graemlins/wink.gif
    j
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We have a snap-on air chisel that is THE answer to this problem. We laugh at rivets now, they're almost easier to remove than bolts.
    BUT, I remember lots of torch/grinder work before this and it did suck. All above suggestions are good to consider.
    If it makes you feel any better, my dad used a hammer and chisel to remove a set of brackets at a wrecking yard one time. Maybe we're all a bunch of meows.....
  12. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    COME AWN PEOPLE!!! I spent 5-8 minutes a side grinding mine out. BIG angle grinder. I wasnt' worried about the bracket I was taking off, so I jut lit into it.
  13. jms
    Jan 24, 2001
    1,683
    ... and hit it with a BFG.
    I suppose you meant BFH /forums/images/graemlins/smile.gif
    ... my dad used a hammer and chisel to remove a set of brackets at a wrecking yard one time. Maybe we're all a bunch of meows.....
    You're probably right. Meow.
    /forums/images/graemlins/blush.gif
  14. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Bushings for me are just a bunch more drilling......
    I used a 1/8" IIRC and drilled all the way through the rubber (nice smell too!) and just kept drilling holes until the bushing started to disintegrate. It's amazing how "frozen" those bushings get in the sleeve!
    Anyway....don't worry too much about putting little "nicks" in the shackle with the drillbit. All the shackles I've dealt with have a metal "sleeve" that you'll still have to cut out, so any damage you do will happen to that sacrificial part anyway.......
    Keep on going! It's worth it......but just takes a while. I think I spent TWO solid days on my shackle-flip to get it done, and I didn't even have to drop the gas tank!!!!
  15. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    I did my '70 in one long day. I hade to drop my 37 gallon tank. Greg check out the red hose from the filler tube to the tank. I know where to get that type of hose in San Jose, it's alot beefier than the stock stuff. You do have to use longer hose clamps with it as its thicker hose than stock too. /forums/images/graemlins/thumb.gif
  16. jms
    Jan 24, 2001
    1,683
    Thanks for the encouragement! I used a drill and small bits on the old bushings when I put the greasable bushings in the front. At least this time the sleeve shouldn't give me any problems, that air chisel ought to make short work of it. Turns out I'll have some more time to spend in the garage tonite anyway, since the Denver airport is stuffed and my lovely wife is stuck in California /forums/images/graemlins/cool.gif /forums/images/graemlins/tongue.gif.
    Almost got the exhaust out of the way (it's a two piece tailpipe, don't want to cut it, but it's stubborn). Frame looks pretty clean where the brackets were, got some black paint just in case. Gas tank is probably next.
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    arrrhggg, dear gawd the memories! drilling out 16 year old rubber bushings. bad times! not that it was hard or anything... but when u had removed 75% of the rubber and pounding on it with a hammer still didnt budge it... good grief it got exhasperating (sp).
    j
  18. jms
    Jan 24, 2001
    1,683
    Got everything done over the weekend /forums/images/graemlins/thumb.gif. Took me probably a total of two days work for the rear; finally, all those phone books came in handy when I lowered the gas tank. The front was a cinch in about half a day. I like the new stance of the truck, but now the 33s look kinda lonely in the wheelwells.... /forums/images/graemlins/crazy.gif
    The rear is now a bit lower (2.5 inch flip/3 inch TC's in front); but I figure I'll wait on zero rates after the rear 60 goes in. Next up are pitman arm and brake lines, not sure yet what I'm going to do about the shocks.
  19. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Congrats, it should seem like a whole new truck the next time you get near a rock.
  20. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
