Shackle flip specs?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Bill4rest, Aug 1, 2003.
  1. Bill4rest
    Bill4rest 1/2 ton status
    Jan 12, 2002
    103
    Vista CA. (so cal)
    Anybody have some messurements for a rear shackle flip?
    Like how far is the shackle bolt hole from the bottom of the frame? How far forward or rearward is the shackle hole from stock?
  2. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    I would like to borrow one that hasn't been installed so i can make a copy if anyone in the area has one.
  3. Bill4rest
    Jan 12, 2002
    103
    Vista CA. (so cal)
    Welp, I guess I'll make them the hard way /forums/images/graemlins/rolleyes.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The shackle is in almost the same spot as stock. It is only moved forward and not much at that (.75" about).
  5. Bill4rest
    Jan 12, 2002
    103
    Vista CA. (so cal)
    Thanks, that's what I figured I'd do. After researching it more, it's seems this method is right on. I want to go 37/38's but I guess I'll see. 8" front springs, 4" rear with a flip.......
  6. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you want to take a look at mine you are welcome to. It seams that the 1st gen shackle flip is a much easier design to make because it doesn't stick so far from the frame. I will be at the SoCalBigDawgs meating this Sat (8/2).
    www.socalbigdawgs.com
  7. Bill4rest
    Jan 12, 2002
    103
    Vista CA. (so cal)
    Dam!
    That would be cool, but I have to finish a YJ cage. Then I get to level my front yard with a bobcat/forums/images/graemlins/thumb.gif
