Shackle Flip Stability
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer_Boy, Oct 21, 2001.
  1. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    How does a shackle flip behave in harder corners. I know that the center of gravity is different because of the lift but does get it even more tippy around town. How would behave under a heavy load in a K20? Thanks [​IMG]
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Mine has been done for about a month now with no problems.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    As for stability, it will be identical to any other lift of the same height. For load carrying, the type of shackle flip that you do may make a difference. Using the ORD or rear spring front hanger, the load capacity should be unaffected. If that little shackle can carry the weight, the bracket is not really an issue. For the cutout shackle flip, strength could be an issue unless the stock bracket is gussetted after cutting. But again, if you look at how thin the shackle itself is, you don't fear the bracket as much. I don't think that anyone on here has ever reported failure of any shackle bracket following the flip.
    <font color=green>There's nothing like the smell of a rich V-8 in the morning...</font color=green>
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Well the flip will add some flex to your rig, but if you plan to tow a heavy load you might want to think about trying to stiffen up the rear for that load. Personally I would just do rear springs if you plan to tow. You could possibly look into an air bad type setup or go the cheapie route and put some Rancho 9000's back there and stiffen them way up when you tow. I've never tried it, but was thinking about trying it on mine. Other then that the flips I have seen done and have ridden in seem fine around town (once you get the whole vibe issue taken care of [​IMG])
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  5. Grim-Reaper
    7,385
    Atlanta
    Re: Shackle Flip is not the issue with towing.
    I'm sorting out the towing issue. I just about flipped my truck yesterday towing 3k. Still trying to get the taste of seat cover out of my mouth.
    At about 70 mph we were going down hill into a slight curve and a wave in the pavement at a bridge pitched the trailer and got it bouncing. At one point the trailer got airborn came down so hard on one wheel the cargo slamed into the side wall and bent it out at a 40 deg angle about ripping the trailer apart. The tounge came down with so much force 3 times it bottomed out the rear supension of the truck and dragged the trailer spare that was bolted to the tounge.The rear supension of the truck then rebounded unloaded and the trailer started to drive the truck sideways when the supension unloaded.
    I don't know how I got it back under control. The first thing through my mind was that I had lost a wheel or the U-bolts broke on the rear axle. We figured out what happen by looking at the 1/4 mile of skid marks left before I got it back under control. At different points both the truck and trailer were sideways. The trailer spare hit the pavement at least 2 times ( to understand how violent that is the bottom of the spare is about 10 inches off the ground. I have never felt it drag before). This was BEFORE I got on the brakes. I have trailered enough that I know when the trailer starts fish tailing you either floor it or ease off the gas. Slamming on the brakes unloads the rear tires and often that will jack knife you. I fought the erge to do so. That I remember. It kept running through my mind...NO BRAKES...do not hit the brakes. I floored it trying to get the truck to pull the trailer back into line. It wasn't working.
    All hell was breaking loose and I was at the point I was just trying to loose speed before we rolled and got on the binders. I just knew we were done. nothing I did with the steering was pulling it out. Just wanted to get rid of the speed. I figured the slower it was going when it rolled the better chances we had at surviving. Old girl pulled it out somehow. I think that the trailer spare hit the pavement the third time about the time I was braking hard. That indicates that if had a lot of weight on the tounge so it would have loaded down the rear tires keeping them intouch with the pavement preventing it from jack knifing. That was right at the end of the skid marks you could clearly see a black mark in the center where that spare was dragging.
    The side of one of the trailer tires clearly shows when it had been riding on the pavement sideways. looking at the skids left confirm the trailer was on one wheel sideways trying to pass the truck.
    Trailer was ballanced right (about 200lb on the tounge). I had several things working against me. My soft rear springs (stock 86's with flip). trailer at about max weight and not enough drop in the draw bar for the trailer to sit level with a load. Not that far out of whack but the trailer was full and the CG was high (trailer is 5 ft from floor to ceiling) I think that with the soft spring, not enough shock valving on the truck and no shocks on the trailer was all contributing factors. 9000's are something I will be looking at. I think I will also be adding an extra leaf to the spring packs. Hate the loss of flex but I do need to bring the rear up about an inch and stiffen up the springs for towing.
    Yes I fully agree at this point to be very cautious if you tow a lot. I'm not sure the flip was a factor in this but I think the suspension flex was. The trailer was jerking so violently on the truck it was getting full compression and extension. I think that it is a negative when towing after yesterdays fun. 9000's on max would have helped. I think a stiffer spring rate would have also been a help.
    Just becareful when towing. I'm not sure that much would have been different if I had been in The wifes stock 79 other than stiff 70's springs and lower CG on the tow rig. I think it would have still happend. The trailer at it's weigh just took that off camber lip wrong and got out of line. I am going to move the axle back on the trailer. I think that will make it less prone to tounge hight.
    I think the towing issue is more a hight/CG, Tire size and suspension stiffness issue than a Issue with the flip. I think any flexy lift no matter how it's done is going to net the same end results as to towing manners. The flip takes blocks out of the mix lessening axle wrap and side to side leverage. I see that as a plus not a negative.
    Women dig dents and flat paint!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  6. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Wow!! ... That's scary stuff!... so, nobody got hurt?!?? It's not clear to me... it did go over?!?
    I agree that the towing issue is a serious one... Many times I have people ask me how to get "long travel" but still be able to tow and haul. I tell them you gotta make a choice..... you can't have both.
    In fact I've come to recommend that my suspension NOT be used for ANY towing...
    Get those 9000 shocks - they will help!
    Marv
    <P ID="edit"><FONT class="small">Edited by marv_springer on 10/22/01 10:22 AM.</FONT></P>
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Another question concerning the shackle flip. If essentially the shackle is reversed (down instead of up), it is no longer than the original, and both the shackle and bracket are stronger, I would assume the shackle flip would be more stable, than say a regular shackle with a 4" lift block. Also less axle wrap. Does this logic make sense or is there something inherently wrong with the shackle pointing down instead of up (the whole compression shackle vs. whatever you want to call the other style)? I just figured the shackle flip would be more stable than a 4" lift block (I still think 4" springs are more stable, but they do limit articulation), plus less axle wrap, but I have never compared the two so I don't know. Anyone else go from a 4" block to a shackle flip (without the block) or vice versa, and how was it?
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  8. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    I agree...but I think when a flip is done there are usually other things done to increase flex in the rear. Namely inboard mounted shocks, removing the overload spring, etc. etc. This can lead to a flexy rig, but as in Grimmy's experience not a very good towing platform. The Springer set-up is not just a simple shackle flip so again it could be less stable when towing.
    I would imagine that a straight shackle flip with no spring alterations, stock shock location, and regular shocks would still be stable enough for towing. I still have rear blocks ([​IMG]) but when I moved my shocks inboard I also removed the Receiver hitch...I still have a bumper hitch for smaller lighter stuff but will no longer tow anything of consequence with my Jimmy. I made my choice and chose flexy over towing.
    BTW the stock orientation is referred to as a tension shackle, after flip is compression shackle.[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Man, that sounds terrible. I've had a long heavy trailer fishtail badly (6 or so oscillations) behind a short bed lifted truck and nearly lost it (the trailer and my mind). Scared the stew outa' me. I can just imagine how that experience (much, MUCH worse than mine) would feel. My hat is off to you. Way to keep it together!
    About the flip. Stephen said something a few days ago that I have never considered before and it got me thinking. I'm going to paraphrase what Stephan said in his post and extrapolate with my own thoughts.
    The manufacturers of trucks (that are actually meant to be trucks rather than Yuppie toys) almost always use a tension type hanger for the rear wheels. Why? Well picture the setup in your mind. As the arched spring compresses, the front is stationary, and the rear of the spring must move back since the spring is de-arching. So, a positive arched spring (bowed down) that is forced flat will be several inches (depending on initial length and amount of arch) longer from eye to eye. Also, (those of you who were here then) remember the discussions between Twizter, Donnovan and myself (and others) last spring? We had a long discussion about spring geometry and how it affects suspension flex. Anyway, the length and angle of the shackle work like a lever to either act against or help the springs ability to move the eyes apart (flex) depending on their relationships to each other. We were talking about front springs primarily, and compression shackles specifically, but similar things are at work here. For those of you who didn't see it, I'll hit the high points in the next 2 sections.
    Now consider a tension shackle. At rest the shackle is generally going to be pretty close to vertical. As the axle moves up (a load is added) the eye moves back off vertical in an arc described by the length of the shackle (arc radius is length from bolt to bolt). Further more, when the shackle reaches some point behind vertical, but before horizontal, the shackle is going to line up with the force (vector) from the spring which was previously causing the shackle to move. At this point the spring becomes (more-or-less) a rigid arch. One of the strongest and most stable architectural designs used to make strong bridges and structures for 1000s of years. This is the "infinity point". Mathematically you would say that the spring rate, beginning with some value at rest, can be described by a curve which goes to infinity (infinite rate, therefore rigid) as the spring compresses (load is applied). End result, the first part of spring travel has a relatively soft rate, but, as it compresses, the effective rate gets higher and higher as the spring approaches the point where it becomes, effectively a rigid arch. This increasing rate is due to the spring having ever greater difficulty moving the rear eye back so that it can flatten out. It gives a relatively good ride unloaded (softer rate) and also allows extremely heavy loads to be carried without crushing the suspension. Even under heavy load the ride is not bad, maybe even better, as the spring rate "automatically" adjusts to the load. This is a simplification and the shape of that curve are affected by may things including the length of the spring.
    Now, look at what happens with a compression shackle (stock front or rear with a flip). The earlier thread with Twizter and Donnovan involved a similar behavior with compression shackles (in the front) when the spring eye (at rest) is forward of the shackle frame mount (common with many aftermarket lift kits). With the spring eye forward of the frame mount, it causes a sort of arch like behavior due to the shackle being more in line with the spring arch (further along the curve on it's way to infinity) resulting in a very stiff initial movement that gets softer as the shackle moves past vertical. Basically, the force vector applied by the spring to that mounting point is almost in line with the shackle bolts (which would describe an rigid arch). In that case, for a more flexy suspension that starts compressing relatively easy (and takes less additional pressure to get the same amount of as it goes further) you want a longer shackle that starts out with the spring eye *slightly behind* the frame mount of the shackle. This effectively starts you out with a given spring rate which actually *drops* as load is applied (spring is de-arched). Anyway, the same thing is happening to the rear springs with a flip. Here, if you look at the forces on the shackle and spring, you can see what is happening. When you add a load, there is a force pressing the frame closer to the axle. Again, this causes the spring to de-arch, which, in turn, causes the rear eye to move back. Now, with the shackle arranged as a compression shackle, the spring eye moving back is causing the shackle to start to act as a lever which actually makes it easier for the spring to flatten out. The over-all affect of this *reduces* the spring rate as more compression occurs. I know I repeated my points a bit but hopefully the rewording helps in getting across the points.
    Summary, shackle flip is not an ideal situation if you want to tow or haul stuff.
    I hope this makes sense...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  10. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Grim, first of all, that sucks. A few questions, though:
    1. Did the trailer tires have the correct, equal pressure, and are they rated for the load?
    2. Single Axle trailer?
    3. Does the trailer have brakes?
    Coming back from Moab this year w/the Blazer on the trailer (about 8000 lbs), I had a rear trailer tire that was losing air (unknown to me). Combined with wind gusts and not enough tongue weight (the primary contributor to my problem, I think), I would occasionally get the trailer swaying. As you mentioned, it isn't always possible to accelerate out of the sway. However, all I had to do was apply the trailer brakes and the sway went right away.
    Also, you may want to look into the factory overloads. I still have them on mine, and can't complain about the flex. At normal ride height they don't touch the spring pack, but will bring up the rear 1/2".
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Oh, and one more thing. A tension shackle forms what is known (IIRC) a "stable system". This means that it "tends" to stay in one place and if moved out of that place, it wants to go back. This is due to the weight of the truck being suspended under the spring eye. A compression shackle is an "unstable system" which means that it really wants to move out of the starting point, and will if not otherwise restrained (by the stiffness of the spring). Picture a ball bearing and a hemisphere (half a hollow ball). With the hemisphere open up (like a bowl), a ball placed in the bowl will move to the center. If you move it from the center, it will go back as soon as the force pulling it off is gone. However, turn the HS over and balance the ball at the apex. You *may* be able to do it but if there is ANY force applied the ball, it WILL role off the center. Not only that, it will accelerate away! This is similar to, but not the same as, the way the spring gets (effectively) ever weaker as it moves from the "in-line" "arch" position.
    Bad Dog
  12. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Wow, that is a marvelous explanation. I don't plan on any wheeling but I would like to have something that would perform better than a block. Guess I'll go with the springs.
  13. Grim-Reaper
    7,385
    Atlanta
    Nope kept it rubberside down. Still not sure how. I fought it hard and gave up regaining control when I locked it down. Maybe the tires sliding kept it from going over. It's all a blur it happend so quick. I shook for about 15 minutes and chaine smoked about 7 cigs LOL. My poor mom was along for the ride.
    She draffted me into helping move my sisters stuff 240 miles. Busted up some of her stuff. Tore up my recently built trailer also. Well the trailer was bought. I just put sides on it and a camper shell so I could also use it to camp in. Never had it that full. Usualy does better with weight than empty. It's a tilt so the axle is a little farther foward to get the ramp angle down for loading. I think that was a big part of the problem. When it got pitching and the tounge came up the CG moved behind the axle so it started wagging. I think I'm moving the axle back to make sure that neve happens again. Just make some sort ramps for my lawn tractor to get in when I need to move it or let the air out of the tires.
    Yeah with that canteleaver design on yours you are right for making sure people do not tow. What if you put a pin to lock that down for street use? Or did you do that? Been a while since I visited your site.
    75 Jimmy, Dollar
    Grim-Reaper
  14. Grim-Reaper
    7,385
    Atlanta
    My truck is a straight flip with stock 86 springs with two over loads. My truck has stiff rancho springs on the front and still stock location on the front shocks limiting droop. I get FULL travel in the rear with shocks in stock location. I run a stock spec Monroe shock for a 4 inch lift. Even so I ramp 752 on a 25 degree ramp with the majority of my flex in the rear. I can just about get the tire on the down side onto the sidewall (close to 45 deg) if I ramp backwards. I fully expect to be in the 900's once I sort the front out.
    Now My shocks were stock for a 75. it may be with the softer spring rate of the 86's that those shocks are valved stiffer. That I don't know. They may be a one size fits all for K5's with no regard to the rivised springs in the 80's. My 75 springs were MUCH more stiff.
    I have removed lift block that were on my wifes 79. BIG improvement. You could feel them causing the rear to wash on curves. Also put a lot of axle wrap into the mix. I had put them on when I was trail riding that truck to handle the extra weight of the recovery gear I carry. it was otherwise stock. I removed them when the gear came out because if looked redneck with so much rake.
    The bottom line is towing with a lifted truck adds some complications. Trailers should be level when loaded. if they are touge high it changes the way the trailer is going to react. When you brake having the trailer level is imprtant. if the tounge is high it pushes up on the rear of the truck. With a flexy truck you can really get out of shape as I did. Low pushes down but too far up or down the trailler will wag. That I was aware of and was a little high but not dramaticly high.
    Also drop draw bars change the way the truck pulls. Idealy you want the hitch in line with the frame or just below. When it's far below the frame it changes the angles the trailers weight pushes against the truck. I have about 8 inch drop draw bar and really need 10 to get the trailer level.
    BE CAREFUL WHEN TOWING. double this if it's a lifted flexy truck.
    75 Jimmy, Dollar
    Grim-Reaper
  15. Grim-Reaper
    7,385
    Atlanta
    EXCELENT information. I had never really concidered the change to the way the spring would react. Makes perfect sence when you relate it to the direction that the force will be applied to the arc of travel on the shackle. I think my issue was more to do with the trailer but I know the flexy rear suspension did not help the situation. That however does explain why the flip can make a other wise stock spring flex much better than if it were in it's stock configuration. Good info.
    75 Jimmy, Dollar
    Grim-Reaper
  16. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    Can you, Or is it safe to put the flips on the front?
    If you cant go over it...GO THROUGH IT !!! <a target="_blank" href=http://www.CaliforniaK5Krawlers.com>www.CaliforniaK5Krawlers.com</a>
    75 Jimmy 11" lift with 40's
  17. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    How much less flex would you get just putting Tuff Country EZ Rides in the rear (4 inch) and some 9000's so you could stiffen it up for the street?
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  18. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    No, you can't. The front is already a compression shackle.
    Bad Dog
  19. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I know this is old but I picked it up on a search and thought I'd clarify a little.
    Russ is right about the tension shackle characteristics. Basically as the shackle and spring flattens out the spring rate will go to infinity. This effect does depend on the loaded arch of the spring though. Most lift springs will start up this steep curve to infinity early because they're built longer than stock and will flatten out more. Stock springs may not get to the "structural arch" point since they'll ride pretty flat. BUT as they go flat and start to reverse arch it starts to draw the shackle forward since the spring shortens as the arch reverses. This will dramatically increase the spring rate since the shackle is trying to swing UPHILL as it moves forward. (it follows an arc around the frame mount bolt). This uphill motion will try to pick up the truck as the spring compresses and will cause the spring rate to sky rocket.
    With a compression shackle, you also have to watch the arch in the spring. When a compression shackle is layed way back, meaning it's at a 45 degree included angle when the main leaf is flat (looks like it would provide a lot of droop), you can get really lousy compression characteristics when the spring compresses past flat. Imagine the shackle layed way back and the spring trying to pull it forward. It's going to pull the shackle end forward which moves it down away from the truck, effectively lifting the truck as the spring compresses. That makes the spring rate skyrocket.
    Moral of the story is there are a lot of factors involved but the gist of what's thown out here is right. We've designed the mounting point for the shackle so that you do get an increasing spring rate as it compresses unless you allow the spring to have a lot of reverse arch. Then the spring rate will start to fall off. This is why it's important to have some kind of overload spring or bumpstop.
    Hope this helps
  20. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    BlazerBoy: so long as you drive in a sane-manner, you'll be fine. If you are ever driving and on turns it feels a little to "floaty" for your liking, just think about good ol' jekbrown on CK5... he runs the shack flip with revolvers!! /forums/images/icons/wink.gif
    J
