Shackle Flip Theory
Discussion in 'The Garage' started by ARAMP1, Mar 20, 2006.
  1. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Okay, I’m a little new to the whole lifting via shackle flip, so I have a few questions.
    Say I do the normal (as in there are a lot of people that have done it) 4 inch flip. The rear of the spring is lowered a certain amount (over 4 inches) to give the axle a 4 inch drop. However, along with lowering the axle, it also moves it forward. (see illustration) Is this were a longer spring comes in? Also, what about pinion angle?
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    That forward movement is negligible. If you do your drawing to scale, you will see the forward movement is not so noticible. I think longer spring=more flex. You can get shims to put your pinion angle back where it needs to be.
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    you also have to factor change in shackle angle into the eqn.... which reduces the change in axle position
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I went from a 4" rear spring with a 10 bolt stock location. To a 14 bolt FF with a ORD 2.5" shackle flip/ORD zero rate/4"spring with the axle pushed back an 1.5" back,and it's perfect.
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Shackle angle has nothing to do with the diff location after a flip. The diff's location is determined solely by the front half of the spring. I found that the diff moves approx 1/2" forward after a shackle flip.
    To keep the rear tires more centered after a flip I'd use a zero rate to push the diff back a little.
    Rene
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    did something about the front of the spring change with a shackle flip? On mine, the shackle, shackly mount etc changed, but the front hanger is stock and unmodified. The word "solely" has me confused here. :)
    As far as the drawing goes, put the lower shackle at a 45-ish degree angle (or whatever ride height will be on your set up) and the amount of axle movement will prolly be less. There is definitely some, but not as much as in the pic above.
    j
  7. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    Jekbrown:
    The front of the spring stays "fixed" to the frame and thus the spring pivots around the front spring eye. Since the front of the spring "for the sake of this explanation" cannot change length the front to back movement of the axle is controled by the "arc" that the axle moves in around the front spring eye.
    You could make a spring with the same rate and axle pin to front eye distance but with a 100' tail and put a 5' shackle on. The postion of the axle under te body of the truck would not change at all in this situation.
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Thanks Brandon, more clearly put than what I wrote...:crazy:
    Rene
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I guess what I was saying is that "yeah, its fixed... but it can rotate about that point"...
    j
