Shackle flip...unforseen probs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Aug 5, 2001.
  1. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    I have an '85 jimmy...currently has a 4" rancho lift, with blocks in the rear. I recently picked up a ORD shackle flip kit, revolvers, extended break lines, and ORD HD shackles for the front and would like to install them.
    Question: for anyone that has installed the schtuff listed above...did said installation cause any unforseen problems? I'm thinking bad vibes, pinion angle issues etc. I already have a vibe problem (classic 208 slip yoke issue...let off the gas at anything over 30 mph and it vibes).
    I know I'll need to go to long-travel shocks to take advantage of all these toys, and will need a set of stock-length u-bolts for the rear...but is there anything else? I am weary of going ahead with the install...because I am not all that rich right now, and I dont want my truck stuck in the shop yet AGAIN for an _unforseen_ problem! ;)
    thanks MUCH in advance!
    J
  2. my only problem was the vibration. just make sure you get the right shims to get your pinion back where it should be. i put 2.5s in but they are not enough. i still have some vibration. i think i'll go 4 degrees. other than that, i love it.
    <font color=blue>Striving for K5 world dominance</font color=blue>
  3. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    1. You might have have have you drive shaft shortened....this kit moves the axle forward aprox 1 inch.
    2. You might also have to shim down your axle.
    3. HAVE FUN!!
    [​IMG]<font color=blue>Donations accepted for the "Build Chaz's 1972 K5 fund"!!!</font color=blue> [​IMG]
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Hmmm wierd. I didnt have to use any shims at all and I get NO vibrations. Was a simple bolt on job for me and all was well.
    Crawlin the rocks with my K5
    <a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
  5. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Where did you get the pinion angle shims?Im in need of these badly.I might just rlocate the spring pads but would like to try shims first.
