shackle flip w/ six inch lift
Discussion in 'The Garage' started by biglou400ex, Mar 9, 2005.
  1. biglou400ex
    biglou400ex Registered Member
    Feb 5, 2005
    9
    West Taghkanic, NY
    I already have a 6 inch tuff country suspension lift installed on my truck and was wondering if the ord 2.5 inch shackle flip out back when installed with the longer hill 4x4 shackles up front will allow me to clear 40"s without too much cutting. I am willling to trim but i figure more articulation is better for the $300 extra of shackle parts then spending the money on cutout flares which i dont really like for $400. I know this is gonna probably cause pinion issues which can be corrected with shims and possibly a transfer case drop. I also have a very competant driveshaft builder in town who can make me some sick cv shafts if necessary. My truck is a resto mod, and i just put all new sheet metal on it so i was hoping the shackles would be the way to go. If anyone has any input on if its gonna work or not let me know. Thanks.
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    The Rear sounds like it should work out ok.
    The front however needs something different than longer shackles. I do not know how much longer the hill shackles are than stock but most likely they will cause some caster issues. About the most length you can add to the factory setup is 1/2" longer shackle so that gets you 1/4" of lift.
    Look at adding more spring lift or an ORD Zero rate for the front.
  3. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    the hill shackles are 2" longer than stock and give an inch of lift. i havnt put mine on yet but i plan on doing it today, they feel like good strong shackles.
  4. miniwally
    Aug 11, 2003
    3,065
    Colorado
    I have never seen the Hill Shackles so I don't know about their "beefyness" I am sure they are good strong parts.
    I would be afraid of taking to much caster angle away with a shackle that is 2" longer than stock.
    Just my .02
  5. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
  6. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I never seen that review on CK5 but they said that they also added a 4 degree shim in the front to correct the angle.
