Shackle Flip. What is it?
Discussion in 'The Garage' started by jk5blazer, Feb 3, 2005.
  1. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    What is it? How much? What does it do? And is it worth it? Thanks
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    The only unanswered question - Yes, it is worth it.
  5. jk5blazer
    Jan 28, 2005
    306
    Braselton, Ga
    sweet. Thanks guys!!! I'll take one.
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    www.sky-manufacturing.com has a nice kit available for less money then the ORD kit. I personally am against the "through the hanger" shackle flips. I think they are 100% ghetto fab and would never consider running one on my truck. If you use the idea and do some quality reinforcment of the stock shackle after a ghetto flip then I don't have a problem with it. Cutting a hole in the bottom of the shackle and just running it like that is ghetto in my book.
    Harley
  8. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    if ghetto gets ya over the rocks.......
    Though I'd recommend gusseting a through the hanger flip.
    Since when were we about looks anyway? My motto often is "ugly but functional" :cool1:
  9. goldwing2000
    goldwing2000 Guest
    If it breaks, it ain't functional.
  10. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    What exactly is a "through the hanger" flip? Which style is ORD and Sky? I will be doing a lift in a month or so with the flip, so Im gonna be ordering parts soon. Thanks
    -Randy
  11. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Where you cut a hole in the bottom of your stock hanger and put the shackle up through the hole.
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    ORD and SKY's kits are true shackle flips using new hangers. This is the best method in my opinion unless you are a decent fabricator and can make your own.
    Harley
  13. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    You don't need to know how to fabricate to use a pair of these. Just a drill and a few hand tools.
  14. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    the first one is sky mfg flip with 2 holes for diff setups.
    second one is ord flipkit and is 1 hole setup but thay have 1/2 3/4 and 1 ton units.
    fliped both my trucks and wow the ride is like a CADDY. smoth as SILK over stock ride.
  15. goldwing2000
    goldwing2000 Guest
    Just be sure you put in new bushings all around. Greaseable ones would be best.
  16. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i tried the thru the hanger homeade flip, rode stiff as a board. problem is the shackle angle is straight up and down with this method. the ORD flip moves the hanger forward 1" to create a better angle. best thing i've ever put on my truck. install can be a bitch for a novice, since you have to drop the tank and remove the factory rivets. if your doing this with someone who has experience it can be done in 3-4 hrs. i'd also recommend getting the fully greaseable bushing kit from ORD while your at it.
