shackle flip + what springs?
Discussion in 'The Garage' started by BigCountryx, Mar 9, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Since my last question was answered so quickly, here goes another. I'm adding 6" TC springs up front. What size (lift) springs do I need in the rear when combined with a 4" ORD shackle flip? I'd like to keep it as level as possible. As always, pics help:D Thanks Scott
    BTW - This is for a 1990 K5
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    Three inch or maybe even four inch depending on how much stuff you carry and how you like it to sit. Butt high or dead level.
    If you go three inch and feel that you need a little more you can add a zero rate.
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    what about a 56" with a 2 inch addaleaf, and a 0 rate?
  4. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    I can add the factory 56's without moving my hangers forward? Will my shackle flip be mounted in the factory holes or will it be moved rearward? How much lift will this mod provide by itself?
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    it wont really provide much lift, Maybe 3/4"
    You just have to move your shackle flip brackets back, I cant remember how far, its been about 2 years since i did it..
  6. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    I was running 4 inch front springs and a d60 (adds 1 inch)
    and 56"s with a 0 rate and a ord flip in the rear.
    with the top off the back would sit a little higher then the front....
  7. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    So maybe I could just add some 2" lift 56" springs out back (if there is such a thing) along with the shackle flip to get my rear up. Then a zero rate if I need that extra inch. How's that sound?
  8. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    I put 3" springs with my 4" flip and 6" tuff country front springs and it seems to sit pretty level, I will try to find a pic so you can see.
  9. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    I think the smallest lift you can get in a 56" is a 4" lift spring.
  10. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    correct, from what i've seen...
  11. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Or you could just put in a 2 inch add a leaf into some 30 dollar junkyard 56"s and be good to go :D
    for some reason i think i remember seeing 2.5 " lift 56"s somewhere, But i cant really remember.
  12. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I have an 89 blazer with 6" superlift front springs and a D60 with a 4" shackle flip and 4" superlift rear springs with a 14ff and the rear sits just a taste higher than the front.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    4" shackle Flip + 3" springs sits pretty level with 6" front springs on 3/4 ton axles. With a D60 up front, I'd probley use 4" springs with that 4" Shackle Flip.
  14. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    mine is on a D60 and a 14ff in that pic, but I think with a top on it and some gear in the back it would sag some in the rear.
  15. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I just did mine and started with 6 inch TC's up front on a D60, an ORD shackle reversal out back with 2 inch TC's on a Corp14ff. Way low in the back. Put in a 1 inch zero rate, still low. Bought 4 inch TC's and swapped them in and kept the zero rate for a total of 9 inches out back. Now it sits slightly high in the rear but I will be hauling lots of stuff so I left it. If I pulled the zero rate I think it would sit level with 8 in the back and 6 up front.
  16. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    Desert Rat, you are the reason I bought the 3" springs in the rear instead of the 2" I had originally ordered :D
  17. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I have TCI 6" springs up front with a 4" ORD flip and TCI 2.5" (or 3" what ever it is) out back and it sits pretty damn level and flexes pretty well in my opinion...
  18. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Glad I saved somebody a headache. Now I just need to sell the brand new 2 inch TC's that I have in my garage........
  19. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    What trucks came 56ers. I think another junk hunt will be underway soon:D
  20. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    put a measuring tape in your tool box, and look at 3/4ton rigs. Some had 52's some had 56"s
