shackle flip with 56"s, 57"' conversion and gas tank questions
Discussion in 'OffRoad Design' started by muddysub, Sep 29, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    shackle flip with 56\"s, 57\"\' conversion and gas tank questions
    okay, this fall, hopefully within a few weeks i'll be installing a 4" shackle flip on my '89 suburban. i have 56" springs, so obviously i just mount it where the existing shackle mount is right? and if i were to go to 57"s one day all i'd have to do is get longer shackles right? or would it be better to flip them around? how hard is it to remove the gas tank? and do i really have to? /forums/images/icons/confused.gif
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Re: shackle flip with 56\"s, 57\"\' conversion and gas tank questions
    I'll take some pics when I do this install for you to check out. I have a K30 with the 56" rears, and I am planning to do what you have talked about. Hopefully will be done within the month. I'll let you know what I find and get the pics up for you to inspect.
  3. muddysub
    Jun 23, 2001
    10,451
    489
    cool, i just heard that with 56"s and an ORD flip i could just bolt up a set of 57"s, is that true? /forums/images/icons/shocked.gif /forums/images/icons/confused.gif
  4. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    It appears that way. According to those I have spoken with, the flip (for something with 56" stock), the ford springs, and the stock shackle creates a good rear shackle angle, and it improves with the use of the longer rear shackle. I will try it both ways and let you know how both work out.
  5. muddysub
    Jun 23, 2001
    10,451
    489
    cool, thanks /forums/images/icons/cool.gif
  6. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    so if a guy had the 52s on his blazer..then wouldnt he get better flex with the 56s?? with enough leafs removed to make them close to the same rates as the shorter ones??just a thought......
  7. muddysub
    Jun 23, 2001
    10,451
    489
    i would think so.
  8. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    My one ton packs have like 10 leaves. /forums/images/icons/blush.gif
  9. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Most guy's don't remove the tank. You can swing it down to get to the rivet's. If I were doin the flip I would remove the tank. Get more room to work,also there would be no fire hazard. /forums/images/icons/tongue.gif
  10. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    And in eric's defense that would be a very good idea....LOL..LMFAO
  11. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    in switching from 56 chev springs to 57 ford springs, would the center bolt holes be near the right position? /forums/images/icons/blush.gif
    tom
  12. muddysub
    Jun 23, 2001
    10,451
    489
    you have to re-drill them about an inch back i think.
  13. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    this can help... F-150 spring help
  14. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    looks like a FEW shap drill bits might be helpful for that task :P
  15. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Shackle angle will probably be Ok with 57's, haven't really checked it out but educated guess says you'll be in pretty good shape.
    As for the tank, I was able to just hinge the tank down on my Sub from the front and snake my arm in there to access the inside. Not too big a deal, just took 2 guys. Really we weren't a long ways away from just removing the tank.
    Best tool for the rivets is a good air chisel running on plenty of air pressure. We finally bought a snap on air chisel and at 150 psi inlet pressure it devours rivet heads. Literally 10 seconds of pounding on it and you're done. Pretty cool. I highly suggest renting/borrowing a good air chisel for this job.....
