Shackle Flip
Discussion in 'The Garage' started by 78GMC1/2TON4x4, Oct 10, 2004.
  1. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    I heard a shackle flip gives you close to 8" of lift? is this true? you go from stock position and have the shackle facing the 9 o clock position which seems like it owuld give you 4 inches, and then turn it down to the 6 or 7 o clock position and gain another 4 inches???????? /forums/images/graemlins/truck.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    ORD makes a 2.5" and a 4" Shackle Flip.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    no, since only one side of the spring moves, you get half of what the shackle moves, so you would have to move the shackle down 8" to get 4" of lift and that is what thr ORD flip does. /forums/images/graemlins/thumb.gif
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no, shackle flips only go from point to 12 o clock to pointing to 6 oclock(5 or so depending on shackle angle /forums/images/graemlins/smile.gif). Never seen or heard of a shackle pointing to 6 o clock, it owuld not work, any weight would push it right up to 12 o clock. Think about it.
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    a "normal" shackle flip gives you 4", thats what i got from mine.
  6. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    I get almost 5.5 on mine and it looks GRRRRREAT!!! I had mine made by "Backyardbuilt"
  7. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    Me, too. Stood up to quite a pounding a couple of weeks ago when I caught air. I put a 4" spring lift on the front, and the flip compensated for the rear "droop" of the stock springs.
  8. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Ig ot a hair more than 4" out of mine, but I used an aftermarket 2" "drop" shackle, but I also took off the overload leaf, AND the broken lower leaf from the main pack. So its got 4 leafs on it, has at LEAST 6" more droop, stuffs to the same point, is VERY soft, and is just a hair taller than it was with the blocks I had when I started. I'm happpy, but I'm questioning the leaf longevity, being that soft.
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Huh? /forums/images/graemlins/confused.gif
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    i thought about it, I don't see how. any shackle will go to any clock postioning, it's the spring that stops it from happening,LMAO
  11. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    no, shackle flips only go from point to 12 o clock to pointing to 6 oclock(5 or so depending on shackle angle /forums/images/graemlins/smile.gif). Never seen or heard of a shackle pointing to 9 o clock, it owuld not work, any weight would push it right up to 12 o clock. Think about it.
    Fixed your quote. And yes a shackle could sit at 9. Just move the rear hanger towards the back about 4", but it would put a lot of pulling strain on your hangers and I doubt it would ride very comfyor perform well. Probably break.
  12. 78GMC1/2TON4x4
    Mar 10, 2003
    167
    Mount.Angel, OR
    ok to clear things up, when i said the 9 o clock position i was talking about standing on the drivers side in the rear. with no leaf attatched. when stock it points to roughly the 12 o clock position. then i thought when turned and pointing to 9 o clock that would be 4 inches, and then pointed in the 6 o clock postion roughly that would give you 8 inches total. a mechanic friend i know did that to his sons truck. His sons 78 K20 had a 6 inch lift springs in the front and blocks in the rear. well he got 42"TSLs and needed to make room. so he did a shackle flip in the rear. on the rear of the front spring they extended that bar or shackle whatever you call it....and then called advanced adapters and they told him of a ya to lift his truck that would cost 10 bucks.....stack like to pieces of 5x5 to get 10 more inches of lift. giving a total of 16 inches of lift. but from the looks at it and that massive lift it barely clears the tires....thats why i was asking
