Shackle flip ?
Discussion in 'The Garage' started by bigchevy80, May 1, 2005.
  1. bigchevy80
    bigchevy80 Registered Member
    Aug 26, 2003
    40
    I was looking through my LMC mag at rear suspensions and the front spring hanger caught my eye...Can you use this as the rear shackle flip? Do you get what im saying??? Take the front hanger and move it to the back and it to do the shackle flip sence to bottom is already cut out???
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Yep, sure can, and several people have done it.
  3. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    thats what i did
  4. bigchevy80
    Aug 26, 2003
    40
    yo 86 banshee do you have any other pics i cant see them since im not registerd???
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Does this work for you?
  6. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Hey sorry if this is jackin the post but how much lift did that give you using those front hangers? hanks for the info.
  7. bigchevy80
    Aug 26, 2003
    40
    Divorced... works just fine thanks! IIRC shackle flip gives your ruffly 4" of lift?
  8. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    well i measured and that hole for the bolt is about an inch-inch 1/2 lower than a stock hanger, so about 5 inches
  9. bigchevy80
    Aug 26, 2003
    40
    Is it a lot of work or more just a bolt on?
  10. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
  11. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    id say he hardest part is finding the mounts and getting them lined up and both in the same spot, other than that drill a few holes , slap some grade 8s in there and go beat it
  12. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I looked at the spring hangers in my LMC magazine and to me they look different than what is pictured. What did yall get the hangers off of?
    I hope I'm not goin crazy from all of this studyin for college finals.
  13. divorced
    Jul 20, 2004
    5,115
    The front hanger for the rear spring for 73-87 1/2 or 3/4 ton 4x4 Chevy.
  14. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Actually etting the hangers lined up is not a problem at all. At least it wasn't on my '79. Aside from the visible factory hanger there is another factory hanger support riveted to the bottom of the frame that the shackle bolt goes through. I just used that to attach my new hanger.
  15. bigchevy80
    Aug 26, 2003
    40
    Thanks for the replys..now i just gotta get a blazer...
  16. durantk5
    durantk5 Registered Member
    Mar 1, 2005
    50
    Greensboro, NC
    i know that this is a really old thread but i was wanting to do the same thing. i looked in the lmc mag. and they didnt sell that hanger. did you guys just go to a junk yard to get them or what? thanks -Nick
  17. idf_johnny
    idf_johnny Registered Member
    Nov 4, 2003
    14
    Elk Grove CA
    I used front hangers off of a suburban. the frame is shaped different than the trucks and have a shorter hanger. I ended up about 2 or 2 1/2 over stock. I wanted less lift so it worked out perfect.
  18. nomadman
    nomadman 1/2 ton status
    Oct 6, 2004
    168
    Enfield, Ct
    You'll find that 2X4 rear spring front hangers work better because they have the correct offset spacing from the frame as the stock ones. I would post a pic of my install but not sure how to get them to show up.
