shackle flip ????????????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ericsoffroad, Jun 4, 2001.
  1. ericsoffroad
    ericsoffroad Registered Member
    May 29, 2001
    27
    wa vancouver
    how much lift should i expect from a shackle flip if i cut out the bottom of my current mounts i have a 1983 chevy k10 lwb that i use for the north west trails aney help or outher info would be help full
  2. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    You will get 4 inches. If you do it I recommend reinforcing it. I did it on my '73 and it works great. You just have to cut out enough for shackle clearance.
    Chad
  3. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    i cut holes through the bottom of mine and flipped it, i reinforced it w/ 1/4in thick plate that i had bent and welded from the outside of the hanger back up to the frame. this worked great and is very stout. i got about 6in of lift out of it (had to reverse shim the rear end)
