shackle flip ?
Discussion in 'The Garage' started by kutter79, Feb 27, 2006.
  1. kutter79
    kutter79 Registered Member
    May 17, 2005
    48
    st. charles MO
    bought a ord shackle flip off a guy on here awhile back just getting around to nstalling it. i was looking a them and wondering which way should the shckle mount go, towards the front or rear. i have stock leafs. im also adding a zero rate and add a leaf. how much longer u bolts 1 or 2 inch thanks for the help.
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    u bolts are 1 inch from top to bottom, 2 inches over all length
    the shackle should go to the rear when on level ground, it will travel to the front when flexed
  3. kutter79
    May 17, 2005
    48
    st. charles MO
    i mean the actual hanger itself which goes on left and which on the right.
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    this is for 52's reverse for 56's
