Shackle Flip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chris12, Aug 11, 2006.
  1. chris12
    chris12 1/2 ton status
    Apr 23, 2006
    267
    Forest Ontario, 1/4 hr from Port Huron Michigan
    Well i plan on doing the 4" shackle flip on my 88 blazer. but how would i gain the 4" on the front
  2. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    springs would be best way. :wink1:
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    There is another way?
    Get a set of 4" lift springs.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I kept stock rear springs with ORDs flip and some machined zeros to correct my pinion angle as I also fitted one of HADs CV props. On the front I used EZ ride springs and zeros to get it level.
    It rides as good as stock now and the flex from the shackle flip and big springs up front is great!
  5. 68on44s
    68on44s Registered Member
    Jan 30, 2006
    42
    arkansas
    I did the shackle flippy on the rear, and went ahead and put 56" springs back there also... then i took the 52" stock rears and put them on the front. That raised the truck almost equally for the price of new nuts and bolts. You can remove leafs or adjust shackle length to equalize the higth.
  6. chris12
    Apr 23, 2006
    267
    Well i will be going the the 4" springs up front just picked a set up .
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You'll prb still need some zeros on the front to level it and you may well have to alter your rear pinion angle.
