Shackle Flip
Discussion in 'OffRoad Design' started by 76_Cheyenne, Jan 24, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I have a 4" Rancho lift on my 76 K10 and the front end is up a few inches higher than the back because of the worn out springs in the rear. Is an option to do the 2.5 shackle flip in the rear to bring it back level. But I am concerned about having the 4"blocks and 2.5" shakle flip. Does anyone have any ideas?
    Toy Eater
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    go with a 4in shackle flip ditch the blocks and get a one inch adaleaf for the rear to leval it out[​IMG]
    wheeling pics
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I would also recommend using the minimum block size so the 4" flip would be best. The only concerns with stacking blocks with flip kits is watching the pinion angle since most blocks are angled and it can move the axle forward in the well for a couple reasons. One is some blocks have an offset pin, and the more lift you add, the more it moves forward with a block and a flip.
    With a 2" block you should have minimum problems.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
