shackle flip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by schmuck, Jan 23, 2003.
  1. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    i see cory perez's article in the tech section about the home made shackle flip that he did has any one else done this? dose it sound like a good idea? any comments probably will be doing somthing similar soon /forums/images/graemlins/k5.gif
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I've done it. No regrets. Ride is good, and have wheeled it a few time with no adverse affects.
    John
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I plan on doing this myself. It looks good to me.
  4. Ben Malinski
    Ben Malinski Guest
    I tried doing a search for the article and had no luck. Where exactly is it? Cory Perez's article on the shackle flip.
    Thanks!
  5. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    ECHOBIT.COM /forums/images/graemlins/thumb.gif
  6. schmuck
    Nov 11, 2002
    523
    click on the technical section at the top of the page and then go down to the bottom of the page when it comes up did you get that
  7. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Shackle flip works good.Turns pinion angle up little and if you have slipyoke in transfer it moves less in and out.Think it lets rear flex better too. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer
  8. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i'm thinking of doing something similar. hacking off an old spring hangar and mounting it upsied down welded under the old one. this gives about an inch and a half, then whatever the shackle gives, so its like 6" then divide by two...3
  9. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I had this same idea. If you cut up a stock rear hanger like you are talking about, could you possibly bolt it to the bottom of the stock spring hanger already on the truck? You might have to do a little grinding here and there to get it seat on there properly. I know welding would we a pretty fool-proof method, but you might be able to accomplish the same by bolting it under the stock spring hanger, similar to an Echobit.
  10. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    EXACTLY what i will be doing.
  11. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I would like to see some pics when you get done and of the install, etc. Are you going to be doing this anytime soon?
  12. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    hopefully by the end of feb
    i'll post some stuff
    Ryan
  13. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    you can all so use a rear frame bracket on the front of the rear springs off another vehicle be it a 2wd or a 4wd they will both work. it will be alot cheaper than buying the brackets from echo or ord. and will give the same amount of lift and the same great ride. just my .02
  14. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    im using a rear bracket from a rear spring...also free.
    Ryan
  15. ZonkRat
    Jan 16, 2003
    1,003
    I used the front bracket off rear springs.Works good. /forums/images/graemlins/thumb.gif
