Shackle flip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85 4x4 shortbed, Apr 9, 2003.
  1. 85 4x4 shortbed
    85 4x4 shortbed Registered Member
    Apr 7, 2003
    20
    How do you do a shackle flip and how much does it lift? What parts are needed also?
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Echobit has a great setup that isn't too pricy. Check out www.echobit.com for more info. His kit provides 5.5" of lift IIRC. I've got them on my truck, and I've beaten them pretty hard. No problems.
    Give Mike a call, or send him an email. He'd be happy to talk to you!
    -Dan
  3. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Check out the tech article on Coloradok5 HERE.
    If you use the search feature, you will find many discussions about Offroad Design's shackle flip, homemade shackle flip's and some others, including Echobit.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    www.offroaddesign.com has 2 kits, one for 2 1/2" of lift and one for 4", $185 each little less for some other rigs. Search there are lots of topics on it. Tech section of the main site has an article or two as well.
  5. 85 4x4 shortbed
    Apr 7, 2003
    20
    does your pinion angle change greatly with shackle lift?
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    echobit, homemade, and 4" I know greatly affect it. Pretty much make it right for a cv shaft or you need shims. I am going to be running blocks till I can afford a CV shaft then I am doing a homebrew flip.
  7. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Welcome to the board! Hint: A detailed profile would help us better answer this question for you. (Don't be embarrassed if it's not as cool as everyone else's, mine's not either) You will also find tons of info in the search. I assume you've got an '85 shortbed? As stated, there are a couple different shackle flips available. Pinion angle will vary depending on your choice of flip heights, springs, etc. How high do you want to go? /forums/images/graemlins/truck.gif
  8. 85 4x4 shortbed
    Apr 7, 2003
    20
    i was just curious about flips
