Shackle Flips, good/bad/ugly???
Discussion in 'The Garage' started by blackblazer717, Jul 2, 2004.
  1. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    hey
    i have 4inch blocks in the rear of my V-10 blazer and i dont like them, i get bad vibrations from pinion angle and i dropped the t-case 2 inch's would shackle flips help to fix this problem? if so is their a company or companys to get them from? thanx
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    hey
    [/ QUOTE ]Get yourself the ORD 4" shackle flip. http://www.offroaddesign.com/catalog/shacklekit.htm
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    Shackle flip would probably help quite a bit. Call ORD and they should be able to help you.
  4. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    The shackle flip won't help if you have vibration from blocks it will probably worsen it as it makes the pinion angle worse. Your problem may be you lowered the t-case too much most only lower it 1". A 4" lift shouldn't give you vibration have you checked the driveshaft u-joints or had the shaft checked for balance.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    With the case dropped it may be ok. On my 83 I did the shackle flip, but the joint on the case side was angled bad, so I got a CV shaft. Since your case is dropped , you may not have that problem /forums/images/graemlins/k5.gif
