shackle flips..
Discussion in 'The Garage' started by blazeonchevy, Feb 1, 2006.
  1. blazeonchevy
    blazeonchevy 1/2 ton status
    Jan 13, 2006
    401
    san antonio tx
    i have alot of questions about shackle flips.. how do they work? can you lift the rear and the front with them? is it a reliable lift for a DD? how much can you get out of them. i wanted a 6" lift. and i thought this may be a cheaper route to take. and how much are they usually? who makes them? i have a 76 blazer. if any other info about the truck is needed just tell me. thanks.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    SEARCH!!!!!!!!!
    Ira
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    its just a different system for connecting a spring to the frame. Not really rocket science... the stock front end uses a "flipped" system.
    No, rear only. The front is already "flipped".
    yes.
    4" generally.
    Use rebuilt stock springs with a zero rate added. That'll be 5"... plenty for anything short of 44s.
    Haven't been in the market lately... last time I checked, $150-180.
    DIY, ORD, Sky, Dunks... there are others. Of all of them I'd choose the DIY kit... plate shackles are always cheaper / easier to make / easier to modify than stock style shackles are.
    hope it helped,
    j
