Shackle Flips
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pr1aw, Jun 7, 2002.
  1. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    I'm going to do a 4" lift. Will a shackle reversal hold up to towing 5500lbs? Or go with the springs in back.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Do springs.
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Doing a shackle flip (using ORD's brackets) will be stronger than stock hangers. Buuuttt... the load carrying capacity will be exactly the same as stock and you will (as with any type of lift) have a higher center of gravity. If you are towing on a regular basis you would benefit from the higher spring rate of new lift springs. Another option might be ORD's 2 1/2'' shackle flip and a 2'' add-a-leaf. That way you would end up with about your 4'' lift, and a slightly stiffer rear suspension, and the cost would be lower than buying new rear springs.
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    i say do springs...thats what i did but in a 6 inch...never had any problems towing or in any other circumstance...
    Later
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Or do the shackle flip for your lift and install some overload air bags for when you're loaded heavy or towing. Then you have the nice ride when light and weight capacity when heavy. /forums/images/icons/wink.gif
  6. behemoth
    behemoth 1/2 ton status
    May 16, 2000
    1,833
    Northwest Florida
    Would air shocks work? Whats an "overload air bag"?
  7. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
