Shackle Lifts
Discussion in 'The Garage' started by MrArmyAnt, Dec 29, 2004.
  1. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    I want to do a s or 4" lift on a 78, and shackles seem to be the best bet. It is my understanding they just work in the back of 4WD? What length shocks need to replace them? Also, where is the cheapest wholesale site too buy shocks? Do they sell front only lift kits? The springs were replaced 10 years ago, but may need to be replaced now as well.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    are you talking about a shackle flip or longer shackles??
  3. MrArmyAnt
    Dec 29, 2004
    662
    Um, flip i believe. the dealys on ORD.
  4. MrArmyAnt
    Dec 29, 2004
    662
    BTW, I am looking there now, and my year is lift only, and is cheaper. what is missing?
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ORD carries shackle flips for the rear of the truck for 4" of lift, you will have to buy 4" lift springs for the fron to match the rear, and ORD carries those also. There flip is very high quality stuff and they are good to work with.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can get a good shackle flip from Sky Manufacturing for $50 less then ORD. There customer service is better then ORD's also. Sky is a great shop to deal with.
    www.sky-manufacturing.com
    Front lift springs can be obtained from Tim (84ChevyK10) or your local 4x4 shop.
    Harley
  7. MrArmyAnt
    Dec 29, 2004
    662
    So just replace springs? What shocks, so farr 100 for rear, plus 4 shocks, ples springs for front
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Run whatever front shock the manufacturer recommends for the front lift, and don't forget new ubolts in the cost of the front.
    Rear you will only need the reversal kit, shocks, and possibly shims to shim the pinion of the truck down for driveshaft angle. For rear shocks I don't know what exactly you will need but I would be shocks for a 6" lift would work well.
    Harley
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    The ORD flips are great. Easy to install (with the gas tank out) and they fit perfectly. Can't say enough good things about them. ORD also got them to me quickly and answered all of my newbie questions without hesitation. I got rear shocks with a lift that I bought that came with blocks and just tossed the blocks in the parts box.
  10. sublmnl1990
    sublmnl1990 1/2 ton status
    Nov 8, 2004
    419
    Virginia Beach Va.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Agree, can't say enough good things about ORD. There customer service was #1 in my opinion. Top quality products, and top quality service. I highly recomend giving them a call and have them put together a complete "kit" with everything you'll need.
  12. MrArmyAnt
    Dec 29, 2004
    662
    So 3 for ORD, anyone else use sky-manufacturings? Also, are th shocks in that ebay store any good? They seem too good to be true price wise. There better then rough country shicks, right?
  13. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    ORD makes good stuff but so does Sky. Sky is also cheaper, but equal in quality easily. Sky also has great service. I have all of Sky's crossover stuff. Pick up the Sky flip kit a set of 4" Tuff Country springs and some shocks u-bolts and brake lines...and you are set.:)
