shackle reversal home made
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazd88, Aug 8, 2004.
  1. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Just wondering if anyone else out there has done the home made shackle reversal. We did it on my buddies truck yesterday after blocks werent enough on a six inch rough country. It rocks! No problems yet rides great and it only took about 2 or 3 hours. It also helped driveline angles but we were wanting to get it a little better any suggestions.
    thanx /forums/images/graemlins/peace.gif
  2. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    you mean like this?
  3. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    How did you make it? I was thinking of making one for my 90 K5. Where did you get the part? /forums/images/graemlins/k5.gif
  4. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    actually we just cut a hole large enough for the shackle to fit through, flipped it, and put it through. im working on getting pics on here at the moment. but no special parts were needed. /forums/images/graemlins/waytogo.gif
  5. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I did this on my ole 83 with the hwlp of a sawzaw and a fellow member,
    one thing to add.. if you can brace the bottom of the bracket to the top, I imagin hard landings or side loads may cause it to fatigue over time. Just weld in some flat-stock and call it good. /forums/images/graemlins/thumb.gif
    Also..any vibes?
  6. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    thats exactly what whe were thinking for support. and no vibes at all
  7. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    kind of a crappy pic.
    [image]http://coloradok5.com/photos/showphoto.php?photo=10465&password=0&sort=1&cat=500&page=1[/image]
  8. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    thats mine
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    This is my version. I first opened the bottom, but ended up having to really open it up. The shackle hit it. So i had to brace it across the top.
  10. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Henry, please tell me your suspension is fully unloaded in that picture! That shackle is back asswards otherwise /forums/images/graemlins/yikes.gif
  11. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    actually, it's NOT!! I used rancho 2" lift springs, but because of the added arch, my 52" springs measured 49 1/2!! it moved my axel foward! shoved the drivesaft right to the bitter end. I haven't had time to work on it at all, but i plan on moving the front spring mounts back 3-4". Hopefully that will put the shackle in a better position and move the axel back 1" from stock. /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  12. micah
    Sep 18, 2003
    374
    Austin, TX
    would be cheaper and easier to get yourself some 56's and a zero rate/longer shackle or something to make up the difference in lift.
  13. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    My original plan was to go 56" springs, but I ran out of money! Since the rancho's were in the truck already, I tried to reuse them. To keep the cost down. I figured at the cost of new springs, I could just spend a little more and go 4 link. But thats down the road a bit. For now, these will work, and cost nothing. which fits the budget VERY well!! /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
