shackle reversal vs. spring lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Buckeye, Jul 26, 2001.
  1. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    For those of you who have been able to compare an all around spring lift versus a shackle reversal, would you share your thoughts please. In particular, a 4 inch lift versus the ORD reversal with stock springs. Thanks.
    1972 K5
    1991 Jimmy
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Does spring lift mean like blocks or lift springs for the rear? I have blocks. I'm gonna get the shackle flip. Better flex that way than if you went with lift springs and not so much axle wrap as with the blocks (which I'm getting a heck of a lot of with my blocks [​IMG]). I'll be getting the shackle flip soon. [​IMG]
    I've got a mind like a . . . a . . . what's that thing called?
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
  3. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    Depends if your existing rears are shot, if their ok I'd go
    withe the flip.
    <a target="_blank" href=http://www.community.webshots.com/user/wheelininco>www.community.webshots.com/user/wheelininco</a>
    " Wider IS Better!!!"
  4. K5Buckeye
    Mar 5, 2001
    75
    WA
    Yes, I'm referring to a rear spring lift.
    The rear springs on my Jimmy are in good shape.
    I was just wondering how the two rides compare on road?
    1972 K5
    1991 Jimmy
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i was wondering about 4 inch lift springs and the 2.5 inch shackle flip. would that be better than 6 inch soft springs?
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I think there are two different schools of thought here. Cost and ease of installation. The springs are more money, but the shackle flip is alot of work. You could also cut the bottom of your existing hanger out and do it for virtually nothing! I did mine a few weeks ago, there was really nothing to it. You can see it on my pickter page. I haven't had any problems and I've twisted it up a little bit. One of these days I'll beef it back up a little. Good luck with your choice.
    "My blazer may be slow, but it goes faster at higher speeds"
    <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  7. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Been runnin mine that way for 5 years. Works fine.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  8. shaneopie
    shaneopie 1/2 ton status
    Jan 1, 2001
    172
    stokesdale, nc 27406
    I am planning on doing the shackle flip on my blazer also. seems like the way to go. We just finished one on my buddies 1973 chevy 3/4 ton truck and we have been wheelin pretty hard in it and it is working out super. SHAKLE FLIP IS THE WAY TO GO I THINK.
  9. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    Hey JimmyJack,
    Did you need to get new brake lines with the flip?
    John
  10. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    by all means do flip it " i'll be your huckleberry" i loved that movie (tombstone)
  11. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Because my rear springs were 22 years old and in need of rebuild/de-rusting, so I went with a 4" Tuff Country all spring lift. For a 4" lift a spring lift seems equal to the stock ones with a block IMO. Stephen at ORD seemed to think anything over 4" lift in the rear you should go at least partial shackle flip.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.alloffroad.com>www.blazzinor.alloffroad.com</a>
  12. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I'm no expert, but from what I remember reading the reason to do the shackle flip is to stay with a softer "stock" spring.
    If you get a 4" spring lift (no blocks) the spring will have to be stiffer to do the same job. My impression is that the shackle flip preserves the ride quality, but allows you to get the truck to the height you want.
    -Greg72
  13. K5Buckeye
    Mar 5, 2001
    75
    WA
    Well, still undecided. My Jimmy is mostly a daily driver. What I need to do is find someone who has the shackle flip and go for a test ride. I appreciate everyone's input.
    Thanks!
    1972 K5
    1991 Jimmy
  14. 90idahoblazer
    90idahoblazer 1/2 ton status
    Jun 24, 2001
    183
    Idaho
    what is and how do you do a shackle flip???
  15. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    A shackle flip is when you flip the rear shackle to go from the spring up in sted of down to the pearch. You buy the kit from <a target="_blank" href=http://www.offroaddesign.com/catalog/shacklekit.htm>http://www.offroaddesign.com/catalog/shacklekit.htm</a>or do it your self by cutting out the bottom of the pearch and reinforcing it.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    And using a lowering shackle to make it higher. My friend has a homeade shackle flip of 5-6"
    Tim
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    And using a lowering shackle to make it higher. My friend has a homeade shackle flip of 5-6".
    Those of you with shackle flips, how long did it take you to install it? Leaf springs aren't so easy to install either.
    Tim
  18. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    Go with the Shackle Flip. while you're at it, get greasable bushings. the Flip also moves the pivot point forward which increases articulation, that's why they look "offset". If your concern is sagging rear springs, use an Add-A-Leaf. I noticed no loss in articulation but my ride improved. Currently I'm running a 4" Tuff Country lift with the ORD shackle flip and Add-A-Leafs in the rear. Never been happier!
  19. TwoCrowsDesign
    Jul 13, 2001
    387
    Every time I get near my Blazer with my grinder in hand I want to attack those shackles. Guess I better get front springs first, otherwise I'll have a comic book looking ride...
    John
  20. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
    The only draw back I have noticed with the shackle flip is it makes the shackle more vunerable to rocks. With springs it stays tucked up out of the way.
    Jim '80 GMC & '73 Blazer
    Tread Lightly!
    <a target="_blank" href=http://www.gmck5.rockcrawler.com>www.gmck5.rockcrawler.com</a>
