shackled flip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigdaddy89, Jun 14, 2000.
  1. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    Has anybody tried using a longer shackle in the rear along with the shackle flip to accomplish a little more lift using the stock rear springs. Maybe the same shackle used on chevys to lower them can be used the same way but with some lift. I don't know if this would make the rearend a little squirely? Any opinion?
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I haven't did it on my truck. I had extended shackles on a S-10 I had prior to my blazer. The only problem would be the increased pinion angle.
    Keep in mind ya all, when you continue to tilt your pinion up, you are not lubricating the front bearing behind the Pinion nut. I counter act this by slightly over filling the rearend by jacking up the filler side.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  3. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    I believe the front bearing gets its oil slung onto, correct me if I'm wrong.
  4. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    I too believe the pinion gets oil. Picture how fast your wheels are spinning at 55 mph then imagine your ring gear, then the pinion spinning 3-4 times as fast. Plenty of oil to "fling around". Maybe 4 wheeling at slow speeds for an extended amount of time could be detrimental but I don't imagine it would..
    Wasn't me.............
