Shackles up front?
Discussion in 'The Garage' started by CHEVY 4WD, Nov 11, 2005.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I started taking measurements and trying to figure out excally how I want to SAS my 99 Silverado (not buying a kit) and GM 47's will fit pretty sweet making my own brackets. But my question is if i retain the stock geometry (the rear sits 3 1/2" lower) but go to a soild mount in the back and put the shackle in the front will the suspenion work as well? I know jeeps have a similar set up but ive never really played with anything but a Chevrolet. BTW its really having 2 K series trucks to take measurements off of espically my dads K5 with body lift :D
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Usually this type of set-up is no good. When you hit a bump the axle will be moving forward as it goes up, and for reasons beyond my knowledge, this is bad. The Jeeps and Fords that have this type of suspension from the factory also have kits that are used to make the shackle mount on the rear of the spring like our Chevys.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i definelty wuold not run the shackle in back. have you ever driven a jeep? you get a wondering feeling at speed, and im sure its even worse with a fullsize. but like its been said, theres a reason the aftermarket makes kits to convert the shackle to behind the axle for ford and jeep.
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    well that sucks it would be so easy to do it this way... but I would rather have it RIGHT than easy www.setstr8.com (fabritech) is where I got the idea for a front shackle
  5. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    For off road use only, this might be just the setup. One advantage is that as the spring compresses, it actually pushes the tire forward or into whatever obstacle is in its way. This should help assuming that you are moving forward over something. Having not seen it applied in any modern rockcrawlers, I imagine that there are many reasons to locate the shackle in the rear.
  6. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    from what ive seen the reason most dont use it is because if you come up to a rock it will push the shackle back and cause it to bend leaf springs. http://www.texasoffroad.net/galleries/ohv/album206/pic_056
    the link kinda shows what i mean
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    that is actually a HUGE disadvantage. Pushing into the obstacle leads to NOTHING but broken leaf springs.
