shackles
Discussion in 'The Garage' started by 409demon, Oct 9, 2004.
  1. 409demon
    409demon Registered Member
    Oct 9, 2004
    19
    Does anyone know the dimensions for the front and rear shackles of a '81 blazer, and how wide the springs are at the end?
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Front or rear springs? What are you trying to do?
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I believe the front shackles are 4" eye to eye and the rear is the same. Not sure on the rear though.
    Spring width is 3" factory in the front. Not including bushings. Rear is 2.5" I believe.
    Somebody will correct me if I'm wrong.
  4. 409demon
    Oct 9, 2004
    19
    I want to make some new "beefy" shackles to put in when I do my axle swap. I would go take my own measurements but my blazer is 500 miles away.
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    if no one else replies, Im going out to work on my blazer soon, so I can get the measurements in a hour if you need them.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what he said. Most if not all aftermarket front springs are 2.5" wide though. THey use bushing to make up the rest. The rear is a tapered shackle so without the exact measurements you will be hardpressed to make a new one.
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    All I got was the front shackle, the rear shackle is overload for my mind /forums/images/graemlins/rotfl.gif
    Front:
    5.5" long
    1 5/8" wide
    4" center to center of hole
    spring is 2 3/4" wide (plus whatever the width of the bushings are) and at the end the spring tapers to 2 3/8" at the end.
