Shackles...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KleanK5, Mar 9, 2000.
  1. KleanK5
    KleanK5 Registered Member
    Feb 18, 2000
    16
    I thought I read in an earlier post about a shackle reverse kit that improved ride comfort, but could'nt find it. Who makes this kit, and does it alter ride height?
  2. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
  3. KleanK5
    Feb 18, 2000
    16
    Thanks for the info. Using the shackle flip to acheive 4" of lift seems very economical at $150, compared to $300 for rear springs (Tuff Country) of equal lift. I priced a Rancho kit (F&R springs) at nearly $700. Other than the obvious price differences what are the advantages of either?
    I'd like to lift my '87 a tad, 4" would be the max (I'm currently running 32's with Rancho RSX's). I have already decided against blocks, but have'nt ruled out the shackle flip. The K5 is used mainly as a daily driver, towing a couple of ATV's alot throughout the summer months, and see's very minimal trail usage, as it is now. I would just hate to opt for the cheaper shackle flip, new front springs and then decide later I'd like to get a bit more aggressive on the trails.
  4. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
    Haven't done it myself, but will be this summer. From what I understand the shackle flip will give you far better articulation on the trails along with the obvious 4" of lift. Leaving the stock flatter springs provides more flex.
    Some folks (Corey's: http://www.geocities.com/Baja/Trails/7252/myflip/myflip.html) have done them by cutting the stock one and dropping in the hole. Free can be good ya know! [​IMG]
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado (a.k.a. ThunderDog)
  5. DangerB
    DangerB 1/2 ton status
    420
    Frisco, TX.
    HEY COREY!!
    COREY
    I like that flip dude. Give us some details. How much lift did it give you? You didnt HAVE to cut the rivets out, right? The shackle bracket mounted in the same spot? Does it limit articulation at all? How wide did you cut it for that articulation?
    DangerBrett[​IMG]
    <font color=blue>life is a race, you have to look good and go fast!</font color=blue>
  6. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    I DONT KNOW BOUT A SHACKLE FLIP KIT ..BUT IF YOU JUST WANT TO IMPROVE RIDE LOOK FOR VELVET RIDE SHACKLES. YOU CAN FIND THEM IN ANY FOUR WHEELIN MAG IN THE BIG SALE ADS.
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM!
  7. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    The reason I cut the rivits was because the torch I was going to use wasn't at my place, and I can't drive the truck with no rearend. Not to mention, I'm not big on large open flames 4" from a storage of 31 gal of fuel. Being a fire fighter, I know how interesting it can get. As far as how wide, It was wide enought for the shackles to swing, and long enough that I was sure it wouldn't hit when under compression or hanging. So far, no problems or complaints. Couple things I had to do were: CV Shaft for the rear, and 2deg. shim to tilt the pinion DOWN so the driveshaft wold be inline when the vehicle was "under power"
    Corey
    88K5
    coreyperez@freewwweb.com
    [​IMG]<font color=blue>Girls Like Guys In Bow Ties</font color=blue>
    <font color=red>http://www.geocities.com/corey_perez
