Shake
Discussion in 'The Garage' started by WinslowS, Mar 11, 2007.
  1. WinslowS
    WinslowS 1/2 ton status
    Jun 1, 2006
    265
    Spartanburg, SC
    I just got the truck running today, drove it around the block, and when I got up to around 30-35 I got a horrible shake from the wheel, so bad that it would be impossible to drive any faster or maintain speed and stay in my lane. My dad thinks it is a tire/wheel issue. Its an 89 K5 with 3/4s from an 82 k20 and ~1/3-1/4 tread 38.5 Gumbo mudders, all of which is a recent addition.
    Edit-3/17/07 Took it to a shop, aligned front end, balanced and trued the tires. It needed a passengers side tierod end, but that was all. It was working fine until this afternoon when I went wheeling, on my way between mudholes it came back. I described it wrong above the shake is everywhere but the steering, It is like the whole truck is shaking. I took some rear shims out when I swapped in the 3/4 tons, and now there is almost no angle between the driveshaft and pinon yoke. It is not shaking often as it was before. Any ideas?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Search "death wobble"
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I was hoping for a thread on Master Shake
  4. WinslowS
    Jun 1, 2006
    265
    Spartanburg, SC
    Read update, not a steering issue.
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    For a vibe free driveline you want your shaft with a double carden joint by the tranny and straight into the diff (diff usally needs angled up a bit), OR you want equal angles on each of the shaft.
    Any other way is going to introduce vibes in the shaft.
  6. WinslowS
    Jun 1, 2006
    265
    Spartanburg, SC
    I'm sort of a noob, whats a double cardon joint? And would these vibes be nonexistant, then so extreme that the car isnt safe to drive. I don't have a tach, so I can't tell if it happens at different rpms, if that would even help?
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    This explains it much better than I can
    http://www.4xshaft.com/driveline101.html
    And yes, you'll get weird vibes at different speeds. As you accelerate, it may be faint at first, then get strong, then go away then come back at a higher speed.
  8. WinslowS
    Jun 1, 2006
    265
    Spartanburg, SC
    I got some shims that were in the back, I took them out with the zero rate when I put the 14 bolt in because I didn't want the front lower than the back, and the shims were increasing angle, while I thought that no angle would be better(I was wrong).
    My other thought is that I have a bad shock. I am going to correct these angles, but the shake doesn't seem consistant with the driveline vibes, because once it starts I have to stop before the shake will stop. I'm thinking the unbalanced tires were setting it off before, and I somehow made it worse offroad yesterday, and so now bumps in the road at higher speeds set it off. I went over 45 for a while, then had the shakes at like 30 on another road. I'm also going to try hooking the swaybar back up.
    Anyone know how to test shocks?
