Shakel Flip Options
Discussion in 'OffRoad Design' started by SuperUnknown, Mar 20, 2001.
  1. SuperUnknown
    SuperUnknown 1/2 ton status
    Feb 8, 2001
    165
    Prince George, British Columbia, Canada
    I am going to put a 4" lift on my Jimmy('88) and like most people, I don't want blocks. I don't want to use a 4" flip because I would like to get rid of my stock rear springs. I am considering using a 2.5" flip and 2" springs and would like everyones opinon on this...
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Why?
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. SuperUnknown
    Feb 8, 2001
    165
    Two reasons:
    1) 1/2 more lift in the rear to compensate for sag.
    2) I was hoping to get more articulation with 2" springs rathere then 4".
  4. BMRCCR
    BMRCCR Registered Member
    Mar 7, 2001
    33
    It's kinda expensive to spend 170 + new springs just for 4 1/2" lift. It should perform well, though. I don't see any problems with doing it, but you could probably just buy the flip and repack your leaves or buy stock replacement leaves.
  5. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    I think you'd get more articulation with stock springs and a 4" shacle flip. If you want an extra 1/2" lift, add a 1/2" block.
    Pete
  6. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    I would just go with the 4 inch flip and the 0 rate spring from ORD and that would make up for your rear sag.
    Scott
    78blazer<P ID="edit"><FONT SIZE=-1>Edited by 78blazer on 03/21/01 06:24 PM (server time).</FONT></P>
  7. SuperUnknown
    Feb 8, 2001
    165
    Well from the posts it looks like it's not a very good idea. Thanks for the input.
  8. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,040
    1,108
    Dallas
    It's not so much that it's a bad idea, because you'll probably get some good performance out of that suspension setup. But for that kind of money, you can get a lot more than just 4.5". I don't mean more lift, but there is a better value out there in terms of overall components.
    David
    '85 diesel burban
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Everybody's pretty much nailed it in the replies. Best way in general is the flip, stock spring and a zero rate kit, or even a full length add a leaf if you want it stiffer.
    Making the world better, one truck at a time.
    SW-ORD
  10. CK5
    May 19, 1999
    21,627
    704
    CO
    I run the ORD 4" flip with ORD 0 rate add-a-leaf and stock springs, sits level and wheels hard. [​IMG]
    Steve
    Mall-Running poseur 4x4 with curb-feelers
