shakes
Discussion in 'The Garage' started by schmuck, Aug 25, 2003.
  1. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    ive got a vibe only when the gas pedal is depressed, and in any gear, ive already replaced the flywheel which was bent and i also went ahead and replaced the torque converter while i was at it and the u joints and i still seem to have this vibe,HELP PLEASE
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    you check the motor/trans mounts?
  3. schmuck
    Nov 11, 2002
    523
    yep the trans mount is new and i just replaced one motor mount and the other one looked fine
  4. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    I had a similar problem once, it turned out to be the drive shaft was out of balance. /forums/images/graemlins/thumb.gif
  5. schmuck
    Nov 11, 2002
    523
    thanks ill check into that
