Shakin, not stirred!!
Discussion in 'OffRoad Design' started by BurbLover, Aug 2, 2003.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Steve,
    I put a D60 on my burb a few months ago and had a problem shaking around 25 mph or so. I replaced the stock steering stab with a single Ranch one I had laying around. Didn't solve all of the problem. Do you think I need to upgrade to a dual stab? If so, any suggestions on style/make? Or, do you think it might be something else? I had someone do a check on the joints & they appeared to be good; however, could be wrong.
    Thanks.
    /forums/images/graemlins/burb.gif
  2. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Sounds like you're describing a mild case of "Death Wobble"....
    Everyone that runs a D60 seems to have that symptom to some degree or another. There's a LOT of info on this site about theories to fix (shimming the kingpin bushing spring, checking front caster, adding a hydro-ram for damping)
    Anyway, it probably won't make you feel any better to know that it's not just you having that "experience" but it seems like people have had decent success in minimizing the problem with a few techniques.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    First thing, do a search for "death wobble". Be prepared to read for a while. Maybe and easier first thing to do is call here and get a kingpin spring and bushing kit and install it. This gets new springs and bushings on the upper kingpin connection on your steering knuckles and this is a common source of problems. If that doesn't fix it, start reading.
  4. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Stephen,
    Couldn't find em on your website. I was wondering a cost. Guess I'll just drop you a landline.
  5. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Got my parts lats night via UPS around 730. Gonna try tyo get them on today, if possible. I was wondering if I can use C-clamps, as I don't have any vise grip clamps. Thanks.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    All you have to do is clamp the parts together enough to start the nuts or bolts, screw clamps should work fine. Hope your wobbly days are over...
  7. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Makes two of us. I got my front axle on stands and my wheels off. Next step is to remove flat tops and see what's there. Hopefully nothing too bad.
    /forums/images/graemlins/thumb.gif
  8. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Got the parts on after a little attitude discussion with the steering arm. Anyway, will be a couple of days before I can check it out. I discovered a few other items that need some attention while the wheels are already off.
    Thanks again for your help with this.
  9. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Burblover...make sure and do a follow up post after you take the burb for a test ride. Just kinda curious of your results. /forums/images/graemlins/thumb.gif
  10. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Well, I made it to NAPA to get the needed parts. When I took off one of the castle bolts, the threads stayed in the bolt. I'd never seen that happen. ANyeay, I took a pick & removed em, just needed a new bolt. figured I'd replace the cotter pins at the same time.
    Anyway, despite my wifes request (she was wearing a skirt), we went to dinner and in the Burb. She new what I'd been doing and explained to her that I wanted to test drive it. 95% of the wobble seemed to be gone. It no longer seemed to shake at the normal speeds (25-35). However, I also swapped my front tires (unitentianal) and I now notice a small bounce at 40-50. I will attribute this to one not so great Hummer wheel that appears to be out of balance.
    So, in conclusion, much better than before. I still plan on upgrading to a dual stailizer setupo, especially when I put my 42x15x16.5 TSL go on.
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    YEE HAA sounds like it worked.
