shaking braking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, May 15, 2001.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    I could (and have done) 100miles an hour. The rig does not vibrate at all. Until I break that is. What can be the reason?
    "K5 Grand GT Blazer Silverado in the Netherlands."
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Sounds like your rotors need to be turned or you got some bad wheel bearings.
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. Sammy
    Dec 8, 2000
    250
    what do you mean by rotors being turned?
  4. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Big question with a lot of answers! Could be a lot of things, but usually not a big problem.
    Most likely, the rotors are out of round. How many miles since pads changed? Ever turned the rotors? Has this gradually gotten worse? When's the last time tires baalanced? may even have bad front end components?
    Details! Details!
  5. Sammy
    Dec 8, 2000
    250
    pads not yet changed. Could be it. But still, what is ment by rotor turning.
  6. backlash
    Oct 21, 2000
    519
    Northern, VA.
    If you were to look at the front edge of the rotor, and turn it, both inner and outer edges should be parrelel and run true (flat). Over time with normal wear this surface will become uneven. Especially if hot, then drive through a puddle of water over years. Quick change in temp, etc. and waters pretty cold there! LOL!
    This is an over simplification, but they can be checked with a dial indicator, but if they are that bad, you can probably see it! Sounds like you may need a brake job. R&R, clean and inspect bearings, turn rotors, and replace pads and service calipers.
    But give more details first
    PS Brandon you type too fast!
  7. Sammy
    Dec 8, 2000
    250
    I will pull sume stuff apart when I get to it and then imput you with more details.
  8. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    A lot of parts stores will turn the rotors for you (shave the bumpy parts off). But beware! If they are too thin to turn, then you'll have to buy new rotors, so be ready for that expence.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Sammy, call around and make sure the place where you are taking your rotors to for the turning can turn your big ol 4x4 rotrs. I ran into that problem here in Nashville. Went to advance hauled them in there, nope we cant turn those things. "You said you could over the phone!!! " Make sure they know what your are talking about (4x4 rotors with hubs)
  10. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Sammy,
    I think they are suggesting you pull the rotors off the truck and take them to a shop that can 'turn' them. (Mounting rotor onto a lathe and have the lathe cut the rotor on both sides with centerline fixed - creates new true braking surface). Do this with every pad change if you can. The worst part is pulling hub - the re-surfacing should be around $20 - $25.
    Watch the process if you can - it is hard to describe.
    Dave
  11. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Also there are shops that can do your rotors while still on the truck. It cost me $45 per side. And took them only an hour for that step. I had other stuff they were doing for me too.
    I think someone got a line of poo. They(autozone and advance) have turned the rotors from our D60 on the work truck. I just think they got lazy.
    [​IMG] Dont steal my truck..I dont need anymore worthless junk over my fireplace.
  12. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    On the truck... that is great! $45 is probably worth it.
    Who got a line of poo?
  13. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Brandon or ftn96
