Shaking in OD
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Oct 22, 2001.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    I have an '84 Blazer with an automatic tranny and 305. This morning, when I put the truck into OD it started to shake until I let off the gas. This afternoon I put it into overdrive again to see if it would do it and it didn't. What would cause this? Thanks
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I had that problem and it was a bad tranny mount. Might just wanna check yours.
    89 K5 Silverado
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  3. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    If it does end up being a bad mount, how hard are those to replace? ShouldI just get a stock replacement mount, or does a company like Energy Suspension make upgraded mounts? The truck does not shake in drive, only in OD.
    <P ID="edit"><FONT class="small">Edited by FL84K5 on 10/22/01 02:39 PM.</FONT></P>
