shakle flip 1/2T to 1 ton..
Discussion in 'OffRoad Design' started by tx79k10, May 24, 2006.
  1. tx79k10
    tx79k10 Registered Member
    May 22, 2006
    7
    Georgetown, TX
    I have 79 K10. If I order the shakle flip with my stock 1/2T rear axle, but upgrade to a 14bolt later will I have to re-order different flip brackets to work with the 14bolt? Thanks
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    1/2 ton and 3/4 ton use same frame hangers. the 1 ton is a diffrent set of frame hangers. moves the springs closer to the frame rails.
    if you have 1/2 ton frame then get 1/2 ton flip kit.
    when you swap to 1 ton rear find a 3/4 ton version direct bolt in. or 1 ton needs perches and shock mounts moved.
    good luck.
  3. tx79k10
    May 22, 2006
    7
    Georgetown, TX
    Thanks for the info, I'm a newb here and I have the 14b ready to go in, but I may look around for the 3/4T version now for the sake of simplicity. :D
  4. sweetk30
    Nov 1, 2004
    25,546
    542
    in the vendor section that you might not beable to look in just under this offroad design section. there is a vendor by the name of cyberfire. he is diy4x4 parts. he just came out with a all new 1 ton version front hanger kit. and if you use this with a 1 ton flip kit that he does also it will work for you if you want to go this way.
