shakle flip & Hitch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Jul 2, 2001.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Is it true that you can't mount a hitch when you have a shakle flip installed?
    "1988 K5 Grand GT Blazer Silverado in the Netherlands."
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    i dont see why that would be true. I assume you're talking about a reciever hitch which should mount up directly under your frame rails. The shackle flip is outboard of the rails. I dont see why a flip would affect a reciever mount. But if you can't use a ready made reciever hitch, fab something up!!!
    Sherman, Tx
    <font color=red>Come Awn yall...Let's go to LUCHENBACH, TEXAS!!!
    </font color=red>
  3. Sammy
    Dec 8, 2000
    250
    Well I thought the flip was also partly under the chassis.
    But with welding up something myself, I have some legal problems in this country.
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I'm thinking of doing one myself. I have a reciever hitch already and it is welded to the frame [​IMG] so I'll have to cut it off cause I can't get to the bolts with that thing in the way. I think it'll work though. I can't see where it wouldn't.
    I've got a mind like a . . . a . . . what's that thing called?
    <A target="_blank" HREF=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</A>
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Are you going with an after market flip or the homemade "cut out the bottom" routine? The only thing I can see with the hitch is trying to mount the aftermarket flip kit. The way I did it was a breeze and the hitch wasnt a factor.
    "My blazer may be slow, but it goes faster at higher speeds"
    <A target="_blank" HREF=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</A>
    Jim
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I've read in past post's that some guy's had to "Notch" ether the hitch or the shackle. To make it work..with a hitch on there rig's
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  7. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I nothched my flip about 1 square inch on the bottom.
  8. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    I didn't want to notch shackle flip nor my new reciever hitch so I used a spacer (large washer) under my hitch. It used the factory holes. I just used longer Grade 8 bolts. Works great. It was easier to install with the gas tank down.
    The Few, The Proud, The K5 Blazer
  9. LA91Blazer
    LA91Blazer Registered Member
    Mar 4, 2001
    90
    I had a few problems with my ORD flip kit install. The brackets interfiered with the OEM frame hitch bolt. I had to remove the forward bolt on each fram rail to get the bracket mounted. I plan to drill out the ORD bracket so I can remount my hitch.
    Love my ORD flip kit real nice work, worth the $$
    BlazingWolf
