Shakle flip ?
Discussion in 'OffRoad Design' started by earl87gta, Oct 20, 2003.
  1. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    will the shakle flip from a '73-87 GM 1-ton 4" lift work with my 72 blazer I thought abought buying a used set.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I have looked on the ORD site and it says it will not work. 1 ton shackle flip is all by itself.
  3. earl87gta
    Apr 6, 2003
    551
    Chuckey TN
    I looked to and seen that Im just wondering how much of a diffrence thier is. They may still work just not a dirrect bolt in.
  4. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    The reason they don't work is because the spring pad width is two inches narrower on the 1 tons, so the flip brackets stay much closer to the frame. There really isn't a decent way to make the flip brackets from a one ton work on a 1/2 or 3/4 ton vehicle.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The height from the frame and the offset from the frame will be different so the later 1-ton flip won't work on the early truck. The spring perches on the axle are the same between the early trucks and the later 1-tons, but the frame width and bracket height varies.
