Shakles
Discussion in 'The Garage' started by MR.4x4, Jul 18, 2002.
  1. MR.4x4
    MR.4x4 Registered Member
    Jul 17, 2002
    66
    Wat are the diference between the SHACKLES and the REVOLVER SHACKLES?????
    Wich is the maximum length of a SHACKLE??
    Thanks for your help!!
  2. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    Revolver shackles are an aftermarket part mostly used on jeeps to increse axle articulation. A shackle on a k5 is found on the rear of the leaf springs and allows the spings to move a little bit.
    There is no set legth that a shackle can be.
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    A revolver shackle is a shackle that is hinged in the middle. It basically rides folded up on itself but when the axle droops, it unfolds to allow for more travel, while a fixed shackle only has forward and backword movement according to the compression of the springs. I talked to a Terra Mnfg Rep at an offroad show last week who said the revolvers weren't actually designed for the weight of a fullsize, but there are people here who run them OK I think.
    Tom
  4. MR.4x4
    Jul 17, 2002
    66
