Shaved the 14b this weekend.....PICS
Discussion in 'The Garage' started by Zeus33rd, Apr 20, 2003.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I didn't get as carried away as I could have, but everything is smoothed out and that big ass lip is gone...
    Took me about...half an hour to do that. /forums/images/graemlins/smile.gif
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    looks good, i wish i wouldve done mine before i put it in my truck...
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Ya know, Ive been looking at that big lip on mine from my front porch lately, (it just stands out like a sore thumb from where I sit outside) wanting to chop it off but pulling my axle back out doesnt appeal to me. Ill take another look at it next time I put PI on the lift at work. Maybe I can do it while its still in w/out having to lay on my back. Guess Im just lazy. /forums/images/graemlins/rolleyes.gif
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That looks almost exactly like mine. I did the same to the D60 front too... Nice job! /forums/images/graemlins/thumb.gif
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Thanx.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Looks good. When I shaved mine I got pretty aggresive on the lower lip and shaved it into the bottom bolt hole. It will still hold a bolt but the threads and hole itself are visible in spots on the bottom of the diff. I had to shave the bolt head too. Now i have a 3 sided bolt in the bottom.
    I am going to have to go back and do some more grinding on it sometime too. I smoothed and shaved the bottom good, but I didn't grind enough from the sides of the diff. I thought it would be enough, but now I know i am going to have to grind some more.
    Looks good though. I am going to finish the rest off like you have it on the sides.
  7. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    That looks good, I need to do mine too. Did you use a grinder ?? If so what size was it. I've been looking at mine and all I have is a 4" grinder, I was just wondering if it is up to the task.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Takes a long time with just a grinder. It's quicker to take off most of the lip with a Sawzall and then finish up with the grinder. I did one of my 14-bolts in about 30 minutes using just the Sawzall and a 4-inch grinder. /forums/images/graemlins/cool.gif
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Same for me. About 30 minutes for each end. Started with Recip to remove most of the material, 4.5" cutting wheel for some tweaking, 4.5" x 1/4" grinding wheel to slick it up. When I was done, the bottom bolt heads on each end were flush. Then I added 1" x 1/4" strap stock to the bottom lip of both covers (ground to match) to prevent peeling. Finally, bent some straps to go over the ring gear hump and angle into the lower reinforced lip of the cover to form a sort of ramp AND to triangulate the lip edge (again, to prevent peeling).
  10. CK5
    May 19, 1999
    21,623
    701
    CO
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ya, I wish I had a sawzall. When I ground mine I used a 4" angle grinder. It sucked. I used cutting wheels (3) to cut the big lip off the bottom. Then I went threw with some grinding wheels and ground the piss out of it. It took quite awhile to get it done. I think it took minimum of an hour, probably closer to 1.5 hrs. I didn't do it all at one time though so I can't really judge the time. But it did suck.
  12. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I like it...flip it over and do the other side to drop the weight, I've droped 80lbs. off my 14FF by changing over to disks, taking that lip off, turning the hubs a little and grinding...
  13. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    sweet!!
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    From start to finish, it took me less than 30 minutes. I used a 9" DeWalt grinder with a cutting wheel to make the intial rough cuts. Switched to the 9" grinding wheel to shape it, then a 50 grit disc to smooth it out. I love that Grinder...Took a cast perch off a 14 bolt in less than 10 minutes with it. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  15. Donna
    Donna 1/2 ton status
    Feb 20, 2001
    2,377
    Gettysburg,Pa
    WOW!!! That looks very similar to what Wayne and my brother worked on this weekend. They shaved mine and got it under the truck. Looks good though!!!
  16. bigmack
    Jan 3, 2002
    478
    Tennessee
    Thanks for the info. I guess I will sawzall first, then grind. I am always hanging that lip on something, or dragging it down the center of a rut somewhere. /forums/images/graemlins/thumb.gif
  17. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I tried using my sawz all...To damn slow. The 9" grinder with the cutting disc took off the majority of the bottom lip in less than a minute. Try that with a sawz all. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  18. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    With the axle out of the truck I used a 7 1/4" skill saw with a metal cutting blade on it. Made short work of knocking off the big stuff. Used an angle grider to fine tune the rest. BTW- you can buy 7 1/4" metal blades at Home Depot for like 2.39. /forums/images/graemlins/thumb.gif
