Shaving 10b front
Discussion in 'The Garage' started by Hossbaby50, Feb 18, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    How much can I shave my 10 bolt front axle and still have enough meat left? I rockcrawl so I will probably slam the diff pretty hard. How much is ok and how much is to much?
    I already shaved about 1/8" and smoothed the diff this afternoon but kinda want to shave more. Thanks
    Harley
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    If you see gear oil stop!!
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The front end takes a LOT of abuse when you happen to get some air time. I would be concerned that removing too much metal could make the housing too weak to handle the stress of re-entry. /forums/images/graemlins/wink.gif
  4. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I'm no expert in the field... but it seems to me that removing metal from an already weak axle would cause problems... unless said axle was under the front of a rig that weighed a lot less than a stock blazer/PU...
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I cut off the ears with a hacksaw and ground off about 1/8" all the way around including the top of the case. I then blended the lip into the rest of the case.
    After that, I went around and removed all the surface defects from the case. Especially on the driver's side on the webbing. I then went around the case with a stiff wire wheel and "polished" it with that. After that I ran a sanding flap thing-a-ma-bob to smooth it out even more.
    If you really want to beef up the case then I'd run a thicker cover. I'd also run a tap into the holes to tap further into the case. I'd then run some ARP bolts in it. That'll get rid of a lot of the flexing of the case.
    The weakest part is still where the driver's side tube goes into the housing. They always break right there.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I picked up another cover today to plate with 1/4" plate for frontal abuse. I think I will just call it quites with the 1/8" removed and blended.
    Harley
