Shaving 14BFF - Worth it poll
Discussion in 'The Garage' started by bigburban383, Feb 26, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    More info...is this an offroad only truggy? Pavement pounder? I would say definantly if it's a truggy /forums/images/graemlins/hack.gifand not worth it if it's a street mostly truck.
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I think it makes a big difference.......it's just not the added ground clearance but also the fact that the bottom of the diff is now smooth and will slide over ruts, rocks, etc...much easier.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    14ff's are low hangin... Trimming, i htink, would help out alot!!!
    I wont name names:
    Wack it!!! /forums/images/graemlins/hack.gif
  5. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I don't think that any amount of trimming would have helped that one! /forums/images/graemlins/histerical.gif
    -Dan
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    This is a no brainer poll /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    start grinding till you see thread or are damn close. then stop. smooth out the sides and call it a day.
    If you are running rocks you will get tired of your land anchor really quick. It sucks big time arse offroad to have that lip hanging there.
    Harley
  8. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    It can not hurt for a DD or a TRAIL only rig...
    I was not going to do mine untill I saw that big arse lip and the first thing that popped into my mind was I am going to hang up on that real quick..
    But I just cut mine a little differant.,I just cut at a angle then smoothed it all out (blended) the main part with what I left of the bolt mounting ring...
    Then capped it off with one of these..
    /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  9. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Sweet...thanks for the replys.
  10. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    nice foot /forums/images/graemlins/histerical.gif
    I do all my sawing and welding barefoot too! Glad to see I'm not the only one who thinks shoes are bad news /forums/images/graemlins/hack.gif
    disclaimer: Do not at any time remove your shoes while cutting or welding anything.
    disclaimer's disclaimer: remove your shoes only if your foot is on fire because you welded your steel toes together. /forums/images/graemlins/dunno.gif
  11. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Looks good! /forums/images/graemlins/waytogo.gif
  12. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Shaving your 14FF won't help you so much as it will help your friends who have to constantly dead lift your truck up an obsticle (I have a lot of friends and my armor becomes grab handles real quick). I did it, love it, and don't know why I waited 2 years for it.
  14. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    do the first chop with a sawsall, that worked pretty good i thought. i removed everything below the center of the lowest bolt hole, does that make sense? then ground it till it was smooth. id say i reduced my un-spung weight by at least a 3/4 of a pound too.
