Shaving a 14bolt............
Discussion in 'The Garage' started by Silver84k5, Feb 16, 2003.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    is there any reason not to use a grinder to shave my 14 bolt? its all i have.
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    That's what I used...
    Rene
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Nope, thats what I did mine with. I used a 4.5" angle grinder with cutting discs to cut off the big lip on the bottom, and then went to work with the grinding discs on the rest to smooth it out. I ended up going a little far and went into the bottom bolt hole. (I had to grind down the threads and the bolt head after I reinstalled the bolt to make it smooth like the rest of the diff).
    I found it worked pretty well, but it took awhile and a few discs. It did alot (not as much as some, but more then most) of grinding and cutting on the axle and cover. I used up 4-5 cutting wheels and at least 2-3 grinding wheels before I finished. The bottom of that diff is a hell of alot smoother though, and it was well worth it.
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Right thx, for the answers guys, Has anyone seen that pic of the guy who made his axle into a 13 bolt? If you could get it to seal up that would freakin sweet... I wish i could find the pic........
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Mine is a 13 1/2 bolt (still 14 bolts on the ring gear) and it has stayed sealed so far. I have only dragged it on a few rocks though. I saw the 13 bolt pics, but that is a little extreme. If it seals and stays sealed then cool, but you are also running into how much material is left before you go to far. I think I have about 1/2-3/4" of material left before I got inside the actual housing. I wouldn't go any more then I did, because if you drop the full weight of a K5 on less you might be asking for trouble.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Damn man, and that thing nevers leaks? dang i wish you had 39.5s on there so i could see what my Clearance would be if i shaved that much.
  8. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    There are only 12 ring gear bolts...
    My 14 is an '85 and didn't have the land anchor lip like my previous 14 which was '77 vintage. The whole bottom area on the newer one is thicker so it can't be clearanced as much. I took the relatively small lip off and smoothed the rest.
    I still smack the bottom of that thing when I wheel, even with 39.5's. I need a rock ring of sorts...the cover leaks already due to rock rash./forums/images/graemlins/angryfire.gif
    Rene
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Or in my case 11 /forums/images/graemlins/confused.gif /forums/images/graemlins/mad.gif
  10. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    I started with a sawsal then a grinder, leving just enoufe room for the bottom bolt. I allso smothed the front edges as much as I could so rocks would slide instead of stick. Becuse I to have 39.5 boggers and still hit.
  11. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I'll use my plasma cutter once the cold weather goes away and the 20-30" of snow we are going to get today.
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I thought that is actually why they are called 10 bolt 12 bolt, etc, because that was the number of bolts on the ring gear. Apparenty I have been miss informed for awhile. Oops. /forums/images/graemlins/blush.gif
  13. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    the GM corparate axles are going by the bolts that hold the cover.dana axles are different. /forums/images/graemlins/grin.gif
  14. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I have heard that too, but I've had a few 14's apart now so i know it's an old wives tale. The 14 SF has 12 too.
    Rene
  15. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    So what yer sayin is that goin by ring gear bolts, "technicaly" there are 12 front axles out there.
    Executioner was right /forums/images/graemlins/ooo.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
  16. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Don't start, executioner! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  17. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    damn it S84, quit doing everything I do to MY rig on YOUR rig...you wanna-be!! /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
    j
  18. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
  19. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    here's the 11 bolt.................
  20. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Here is what it would look like with 39.5's I shaved right up to the bottom bolt and smoothed it out all the way across.
