Shaving Drip Rails
Discussion in 'The Body Shop' started by zcarczar, Dec 11, 2005.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Im getting ready to repaint my new tow rig in the next couple weeks and want to shave the drip rails, I know they screw on and I will have to weld up the holes, anything else I should look for or watch out for when doing it?
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Just make sure that your door seals are in good condition and don't leak air, otherwise you may get water leaks. You can check your door seals by turning the air/heat on full blast and shutting the doors, then hold a tissue and move it around the perimeter of the door and see if it moves. But I think the only function that the drip rails serve is to make sure you don't get dripped on while entering/exiting your truck.
