Shaving the 14 tomorrow
Discussion in 'The Garage' started by firefighter184, May 19, 2006.
  1. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    I bought some cut off wheels for my grinder, skinny little Hiltis. They suck. Blew one apart in like 5 minutes. Anybody know if there is a thicker more heavy duty type cut off wheel out there? Brand?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Don't know the brand, but I've got a crap load or 1/8" thick cut off wheels. So they are out there. I used a sawzall to cut mine then finished off with a grinder.
  3. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    I picked mine up at Home Depot, little 4" HORTON discs. You'll go through a few but they are cheap. I bought 4 or 5 and ended up using 3.
  4. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    I used my Porter Cable port-a-band saw then a 4 1/2 in grinder to do the little bit of rough grinding then a air angle grinder with sanding disc's to smooth it all out, was easy.
  5. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Those things are so nice to have. :thumb:
    Hey John, Scott's got one up at his shop. Might ask him about it but you'd have to drive up there.
  6. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    I'm thinking about using the sawzall and then cleaning up with the grinder...
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I have some Dewalt discs that hold up very well. Got them at Lowes. The sawzall looks like it will be better way to go though, that's what I'm planning on using.
  8. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I just went and bought a new flap disk and used it. Didn't take too long
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I rough cut it using 1/8" cut off wheels I got from a tool shop. Can't remember the name of them, but they held up very well. I went through 1 1/2 of them. I finished it off with a 60 grit flapper disc. Took me less than 2 hours from start to finish. I even took the "horns" off the top of it. I didn't go as far as some do on the bottom. I left it even with the rock ring.
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    What about an abrasive cut-off wheel on a circular saw? Thats the route I was going to go... Got the wheel at Lowes. Haven't tried it yet though...
  11. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Why not? As long as you can keep control of it.
  12. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    got a porta band and a sawzall if you need to borrow them you can.
  13. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I also used a Sawzall for the major cuts. Used a blade called "The Ugly" that I picked up at Walmart. :) Finished up with an angle grinder; first with a rough disk and then with a flap wheel. Took maybe all of 30 minutes. :cool1:
    Oh yeah, it's WAY easier to do it with the axle upside down, before you install it under the truck. :rolleyes:
  14. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    That is how I did mine as well. But I didn't use the flap wheel to finish, just a finer grinding disc. I think it was a lot easier sitting in a chair than laying under the truck.
  15. cbbr
    Jul 17, 2004
    14,681
    I use that setup to cut metal all of the time as long as I am working on a bench or sawhorses where I have some control.
  16. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    If you go to a welding supply place, they have cut off disks that hold up WAY better than home depot junk. The circular saw works great, I use it all the time with a metal blade. But when I shaved my 14b, I went with the easiest and cleanest, a portable band saw of course!! I love mine.
  17. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I used the porta-ban aswell, then a 8" grinder, makes quick work of it:D
  18. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    are you guys getting hung up on the axle or are yall just bored?!?!?!?!?!?! :haha:
    is a shaved 14bolt really needed???? :crazy:
  19. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Mine was already out, so why not:D
  20. garlicbreath
    May 17, 2003
    1,136
    Denver
    Tie an anchor to your ass and see how many curbs you get hung up on!:haha:
    No, I have been caught on that lip a few times. It ain't easy to drag across a rock on it gets caught.
