Shavings in the crank
Discussion in 'The Garage' started by FMJ, Feb 10, 2005.
  1. FMJ
    FMJ Registered Member
    Dec 29, 2004
    94
    Duluth, MN
    I put my 440 together recently, thought i did everything right and kept it clean...but, I took one of the rod caps off to double check it was on right and i noticed grooves running down the middle. So, I decided to tear the engine down again becuase I thought i wasn't clean enough and i was worried about it. Come to find out when i get the rods off, there are still shavings inside the oil passages of the crank...WTF. I had a crank grind and polish and stuff but i sat there and waited while it was hot tanked...I'm going to go talk to the machinist tomarrow and see what he says. Surprisingly i'm not that mad.
  2. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    You still have to clean the oil passages even after it is hot tanked.
  3. FMJ
    Dec 29, 2004
    94
    Duluth, MN
    that would of been nice to know.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Clean EVERYTHING before reassembly....NOW YOU KNOW :waytogo:
  5. FMJ
    Dec 29, 2004
    94
    Duluth, MN
    I find that i learn from my own mistakes way to often.
  6. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Makes you better than most then....
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    be grateful ya found it now. :D
