She Bangs, She Bangs
Discussion in 'The Garage' started by bigburban383, Mar 13, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    My truck is complete. Although I think im going to break the tranmission or transfer case. It spins the wheels when I goose it /forums/images/graemlins/peace.gif /forums/images/graemlins/bow.gif
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    what kind of numbers do you think you have? HP and TQ wise
    you would be suprised what a 700R4 can hold as long as its not overheating
    Also just wonderning what kind of gears do you have?
  3. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    320 hp and 400 ftlbs.
    I have 4.10's in the rear also running 35's.
  4. ryanvz1
    ryanvz1 Registered Member
    Jan 20, 2004
    34
    Are you asking for something to go wrong having all the bad stuff in one spot at one time? 700R4, stock drive shaft, and NP241; I get chills just thinking about it. Please don't tell me you have a 10-bolt front.
  5. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Pretty ballzy to hack on someones ride when you are new and don't fill out your profile. /forums/images/graemlins/rolleyes.gif By the way welcome to CK5. /forums/images/graemlins/waytogo.gif
  6. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    i don't know what will go first, but you should try to get it on film! /forums/images/graemlins/thumb.gif
    my guess is u joint /forums/images/graemlins/grin.gif
  7. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Im guessing he has a TH400 HAD Shaft and NP205 D60...
    I think your rig will hold up fine, but ofcorse if you push anything hard enough you will have problems
  8. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    d. Other (U-Joint)
  9. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    What do you have up front? If it is a 10 bolt (like mine) it will be the right front inner and stub. /forums/images/graemlins/burb.gif
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] You are pretty close to what I have. Desk top dyno says 355HP and 446 ft lbs with my 406 but i don't think I'm making quite that much at the crank but near that.
    I'm running a built th700R4 with custom driveshafts through 4.10's and 35's now and am content but I ran a stock th700 and stock driveshafts for a while and never had any problems but I wasn't doing rock crawling either.
  11. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I have a 10 bolt front end, but the gears are different than the rear so I wont use it /forums/images/graemlins/dunno.gif
  12. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    d. Other (U-Joint)
    I thought about those, they are so cheap and easy to replace (rear) that they are just like a fuse.
