She says I need to make my hose longer!
Discussion in 'The Garage' started by Quack_Addict, May 9, 2002.
  1. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    I changed the oil on my `96 GMC yesterday and figured I should probably grease the front end. I have a pretty good grease gun... but the hose is only about 10-12" long.
    You need 3 hands to grease a front end with this setup - one to hold the hose on the grease zerk, one to hold the gun and one to pump the handle. /forums/images/icons/mad.gif I felt like a monkey under the rig trying to use my knee and leg to hold the back of the gun while I pumped the handle. All this while I'm on my back, under my truck, with my girlfriend laughing so hard she almost started to cry. When I explained what I was doing, she said I need to get a longer hose /forums/images/icons/crazy.gif. That was the final straw... it's time to get a longer hose.
    If any of you guys/gals have run into this and gotten as frustrated as I did yesterday, FYI, Grainger has longer hoses to fit grease guns... about $10-15 for 22-24" hoses.
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    hmmmm...never had that prob with my solid axle.../forums/images/icons/wink.gif/forums/images/icons/laugh.gif/forums/images/icons/wink.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Fooled me there for a moment. /forums/images/icons/laugh.gif "Need a longer hose." /forums/images/icons/laugh.gif
    I was about to suggest you to have me come over and give a longer hose! /forums/images/icons/laugh.gif
    Seriously, I have had that problem with wishing I had a third hand, but I went out and got the type of grease gun that you can use one hand and squeeze the handle while holding the hose with the other hand. Works great. /forums/images/icons/wink.gif
  4. Quack_Addict
    Feb 24, 2002
    119
    Michigan
    Hitting all the grease zerks on the `96 with IFS... almost an hour of cussing and fussing.
    Hitting all the grease zerks on the `84 with SFA... maybe 10 minutes and really easy (only took 10 minutes because I had to jack the rear axle and spin the driveshaft to get U-joint zerks). <font color=blue>I thought technology (IFS) was supposed to make life easier???</font color=blue>
  5. laketex
    6,220
    North Texas
    no, that technology is supposed to make life harder forcing you to go to the dealer since the cost is at least less than throwing wrench after wrench out in the yard from frustration./forums/images/icons/wink.gif
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    I think they have pills for that nowaday's /forums/images/icons/smile.gif
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My wife's '94 Sub is fairly easy to grease. You just have to swing the plastic air management shield down out of the way. Look closely and you'll see that the 2 front attachment points are spring loaded shoulder bolts. They let the shield hinge down for easy access to the tie rods, pitman arm, etc. Just remove the rear bolts and swing it out of your way.
    And oh yeah, like Wes said, a pistol-grip grease gun is much easier to use. /forums/images/icons/cool.gif
  8. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Or even beter get the pistol grip air powered grease gun.
  9. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,793
    101
    Paducah, KY
    laketex, I disagree. That means you sell your IFS POS and buy a K5 or other solid axle truck./forums/images/icons/smile.gif Like me. Anyone want to buy a 92 Blazer K1500?/forums/images/icons/tongue.gif
  10. Quack_Addict
    Feb 24, 2002
    119
    Michigan
    The `96 with IFS is the daily driver... I have 3 trucks with SFA. The older trucks just don't get the MPG's I need to get driving 60 miles to work one way /forums/images/icons/crazy.gif
    1983 K10 4x4
    1984 K20 4x4
    1987 K20 4x4 Suburban
