sheared off spring perch pin.
Discussion in 'The Garage' started by harry, Oct 29, 2002.
  1. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    any ideas on what I should do? should I just weld on a nub and grind it down to fit or rebuild the axle with spare part I have laying around.
    thanks
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Do you mean the centering pin in the spring?
    Go to your local spring shop and buy another one.
    Drive the old one out of the spring pack and install the new one.
  3. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Put a clamp on the pack before take anything apart. It will make it easier to put them back together. Assuming you ment the spring pin. BTW, they are less than $10 for 2.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The "nub" is part of the pin that goes through the spring pack. A new pin costs $3. The spring perch may look flat because the end of the old pin is stuck in the hole. Fish it out, install the new pin and bolt everything back together. /forums/images/graemlins/cool.gif Use the C-clamp to control the spring pressure as you take it apart. Line up the springs so that the new pin will slip in and then use the C-clamp to press the spring pack back together. Tighten the nut on the pin, then cut off the excess threads (the pins are 5 or 6 inches long to start with). /forums/images/graemlins/thumb.gif
  5. harry
    Feb 9, 2001
    106
    san diego, CA
    Thanks everybody,
    it was sheared so clean I thought it was part of the axle. /forums/images/graemlins/thumb.gif
  6. tRustyK5
    Jul 23, 2000
    36,184
    1,393
    E-town baby!
    If you want a strength upgrade get center pins for Ford springs...they're 7/16" compared to the tiny 3/8" pins on the Chev springs. You'll have to ream the holes in the springs and perches but they should last longer...
    Rene
  7. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Since you said it broke flush and you couldnt tell the difference between the perch and the pin, I am assuming its on the differential side this happened. I had to do the exact same thing a week or 2 ago.
    Have fun getting it out. /forums/images/graemlins/eek.gif
  8. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    What did you do, drill out the broken stuck piece and install a new pin in the pack? Yes, it is on the Dif side.
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Installing the new pin was the easy part. Getting the old nub out was the challenge. I ended up drilling it into swiss cheese to make a bunch of thin passages basicly and used a slide hammer w/ a screw in the end. Screwed it in and gave it a few knocks. Good luck.
    Also hose down the nub w/ WD-40 or something similar. I also tapped mine back in a bit just to get it broke loose. It was just that much more I had to pull out, but I made sure it wasnt rusted solid.
