Sheet metal to do floor replacement, what size
Discussion in 'The Garage' started by jjlaughner, Apr 22, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    What gauge sheet metal should I use to replace the floor areas above the body mounts? The mounts are not in bad shape, I'm thinking of buying the slip overs and then welding in the floor pieces. I also need to replace the rear tailgate area, is there a corrigated sheet metal I can get to replace the back section without buying the 2-$75 panels from LMC or other places? /forums/images/graemlins/tongue.gif I basically am wanting to buy a couple sheets of metal to cut and fit to what I need /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
    While I'm doing the mounts I would like to do the poly bushings and some lift pucks as cash allows!
    What did you use, good/bad, ideas?
    I have rust int he floor panels so I may try the plexiglass peep-holes in the floor boards that where descussed a while back /forums/images/graemlins/grin.gif
  2. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    i bought a sheet of 16guage for mine. make sure you put a rust preventer on it or some primer of some sort that plain sheet rusts very fast
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I just did this to my son's new K5 project. 16 guage for the floors, and cut an extra piece (like factory) to go over the mounts. On the back, we cut out the flat metal cross piece which has the rear body mount built in. If you cut about 1/2" behind the forward edge of the rear "C" chanel (the flat metal piece) then it will come out and leave the floor (you'll miss the spot welds). On my son's, the only damage to the corrugated floor was at the very end and this got rid of it. I replaced it with a 2"x3"x3/16 square tube all the way across, extending under both bed sides (so I can tie in the bumper ends). To replace the mounts, I welded the 2 flat pieces of steel from the old piece to the bottom of the new piece. Then, for a spacer (replacing the stock sheet metal spacer) I used 2" lengths of 1"x0.120 tube with 3/8" spacers to locate them correctly.
  4. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I dont know if you're doing the fronts too or not, but emmetology101 (mike) is selling 2 new front pans for $20 each...
    I've never had to deal with rust till now and i'm just as much of a novice as you...
  5. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    1/8th inch boiler plate and make all the floors flat, just save the tranny hump. thats what i am going to do if i have to do mine ever again
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    where do ya'll get all this plating and sheet metal from, i haven't found any sources!
  7. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    [/ QUOTE ] Old bent chevy hood thats where.... /forums/images/graemlins/thumb.gif
